Question about Linksys WVC54GCA Network Camera
If I unplug one of my cameras it changes its IP address, somtimes it changes to the same address as one of my other cameras, also when I am away from home I cant monitor my cameras but I can while I am at home
    President:
  • 8,637 Answers
Once you have properly installed your camera drivers, DO NOT unplug the USB port as it will cause the drivers to become corrupt . Alwayw unplug them after you have shut down your computer. Like wise connect them back up before you start the computer.
Hope this is of some help. Bud
Posted on Feb 28, 2010
Testimonial: "they are not wired they are wireless thaks"
How to configure huawei hg533 router for home network
William the more information you can provide the more accurate can be our brain trust community's answer.
What I have to guess is you added the cameras to an existing network.
What you need to provide is how are the camera's getting their IP addresses ?
How are the PC getting their IP addresses.
My guess
Go into the router settings and look for DCHP server. Look at the leases issued and change the IP addresses that are assigned to the cameras to Static rather than Dynamic. if the cameras are getting IP address from DHCP. server rather than being set up manually..
If you manually set up the IP addresses on the cameras then alter the available ip range on the DHCP server to avoid the IP addresses assigned to the cameras. As an example say the DCHP range was 192.168.1.1 to 192.168.1.254 then alter it to be 192.168.1.21 to 192.168.1.254 and then hence the ip addresses 192.168.1.2 to 192.168.1.20 are used on static ip addresses like printers and cameras devices.
How do you log into the router
go to the internet browser and type in 192.168.1.1 and it should bring up your router The user name is most likely admin and the password will be admin by default. If no one has changed them.
I have looked at the usre manual but it does not spell out how to change the DCHP ip address ranges leases out or the way to change the ip addresses leased out to static for the cameras. I think you will find some sort of setting in thew dhcp menu option of the router.
What
I think is happening is called an ip address conflict. And the above suggestions should stop this from occurring when you reboot the IP address is re assigned and the DCHP server could be issuing ip address leases to your p.cs that are already staticly assigned to your cameras.
Apr 03, 2015 | Computers & Internet
Change ip address
Type cmd in Start menu-Run. A little black window will open. Type: ipconfig/all and Enter. It'll list your IP among other info.
If you want to change it: Start menu->Control Panel
Type "adapter" int the search box. You'll have "Network and sharing Center". Click "View network connections". Select "Internet Protocol version 4 (TCP/IPv4)" and click Properties. There you can change your IP settings.
Jan 17, 2014 | Lenovo IdeaPad Computers & Internet
Lost ip address
They most likely mean serial number.
An IP address is issued by a router and can change from time to time when you connect to the router.
May 17, 2013 | Sony Cyber-shot DSC-T90 Digital Camera
I need to change my ip addres, i have an acer aspire with linux
This computer as any once assigned a IP address is locked to it
Jul 19, 2011 | Acer Aspire One PC Notebook
I have a ps3 and belkin router and when i try to go on line i can play somtimes and somtimes i cant.and i notetist at the bottom of the screen that it says nat type strict.how do i fix this.
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Jan 09, 2011 | Belkin F5D7234-4 Router
Hi, I'm having trouble with changing the IP address on the SecCam
you can try this http://www.whoisxy.com/ ,here i got the details about the dns query ,ip to domain ,domain to ip etc........you can get more about the ipadress......
Jul 13, 2010 | D-Link DCS-5300 Network Camera
Not showing the network ip address. Note i changed it from 192... to 172... and now trying to go back to the 192.168... network
Set the camera to "automatically obtain an IP-address".
Connect the camera, via an Ethernet network cable, to a router.
The router will supply a valid IP-address to the camera; much simpler than trying to "manually" set an IP-address, network-mask, and gateway IP-address.
Dec 08, 2009 | Veo Observer Network Camera
My problem is I cannot access my router to enter my dvr information to view my cameras on line
Get to a command prompt and type 'ipconfig' - no quotes.
You will see some ip addresses listed. The gateway ip address is the ip address of your router. Put that ip address into the address bar of your web browser and it will take you to the router config page. This is where you can do port forwarding if you want to be able to view the cameras from outside your network. Post a comment if you need any more help.
Or did you just forget your router password........or is the router not responding......let me know :)
Sep 05, 2009 | Computers & Internet
I unpluged my remote camera monitoring system and it lost its ip adress
The IP address on your camera system is probably setup using DHCP. This means that the IP address it's given will change over time. There's an easy way to find it. Log into your router, and locate an option called "DHCP Clients Table". This will list every system on your network, and one of them has to be the camera system.
If your router does not have a HDCP clients table, then you'll have to either do a network scan using something like bluesportscanner, or nmap, or to log directly into the camera system using a serial cable or something similar.
Comment back with your specific camera system model number, and I can provide more assistance.
Steven
Aug 04, 2008 | Computers & Internet
Panasonic bl-c20 wireless network camera
Try this - unplug the power from the camera (and the ethernet cable if it is using one). Locate the 'Factory Default Reset' button on the camera get a paperclip and straighten it out. Plug the power back into the camera and press the reset button with the paperclip until you see the indicator light flash and go out (about 10 seconds). Now attach the ethernet cable to the camera and into your router and insert the Panasonic camera utility disk into your computers CD Drive. Run the setup utility from the disk and after a few minutes it should find the camera and you can follow the instructions for a new set-up. If the camera has been on more than 20 minutes when you start the setup utility, unplug it for 10 minutes and try again. Oh, and turn off Windows firewall while you are doing this.
Oct 31, 2007 | Panasonic BL-C30A Network Camera
Linksys WVC54GCA Network Camera Logo
136 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
