Question about Nikon COOLPIX P4 Digital Camera
Lens does not retract fully
Dropped camera accidentally with lens extended - and now its still about 2mm extended, with cover shut, and "lens error".
Is this repairable? Any suggestied fixes?
    Genius:
  • 3,422 Answers
Please follow these instructions to fix the lens problem:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on the kitchen table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum cleaner.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. Take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. A lot of people have reported success with this method. HOWEVER, there is some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables.
Fix #7: Try forcing the lens. Many people have also reported success with this method. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include pulling, pushing, rotating or twisting on the lens barrel while hitting the power button. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the lens barrel side that has the largest gap. While doing these, listen for a click that indicates that the lens barrel guide pins have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
If this still doesn't fix your problem then the only solution is to get it repaired.
Main support number: 1-800-NIKON-UX , 1-800-NIKON-US
Goodluck..
Posted on Feb 22, 2008
    President:
  • 1,944 Answers
Are you able to gently move the lens?
  • Damen Wong
    Damen Wong Feb 22, 2008
    What happens when you turn it off and then on?
When I turn off my CoolPix S6 the lens would close completely. When I turn on my camera the lens is completely open and the screen just says lens cover error.
The lens is damaged and needs to be replaced. Sometimes with use or maybe an accidental hit to the lens can cause a malfunction to the camera resulting in that error. Also if you for example took the camera to the beach, getting something like sand in the camera can jam up the lens and prevent it from fully extending or retracting.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mike_005777b2fc6bfc30
Mar 24, 2011 | Nikon COOLPIX S6 Digital Camera
I dropped my Nikon Coolpix L18. The lens does not come on and it gives lens error. the portion which covers the lens seems to be loos. I am in Africa and ready to try every thing to get it working to get...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Feb 21, 2011 | Nikon COOLPIX L18 Digital Camera
I Dropped my camera model c330 and the lens will not return. I get lens error codes 22 and 12 and the camera will shut down.
Jan 02, 2011 | Kodak EasyShare C330 Digital Camera
The camera lens wont zoom it say lens error and the shuts off
Jul 30, 2010 | Cameras
What can i do if my ixus 55 has been dropped on the ground and it can't work? i mean, i accidentally dropped it on the ground and after that, it could not be turned on again. i tried every thing. how can i...
Jun 18, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Lens error
May 28, 2010 | Canon Powershot A1000IS Digital Camera
The lens does not fully retract when turning the camera off, i think the kids have dropped the camera on the front when the lens was out
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 16, 2009 | Canon PowerShot A75 Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
Nikon COOLPIX P4 Digital Camera Logo
153 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
