Question about Pyle PLR22MPF AM/FM-MPX MP3 Playback with USB/SD/AUX-In
Remove knobs on pyle plr22mpf radio
Cant figure out how to remove the knobs on a pyle plr22mpf radio
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
How do i remove just the knob?
The wiper knob has a clip you release, and the headlight knob comes out of the switch with the rod attached. There is a button on the headlight switch you press to release the knob and rod together.
Oct 04, 2012 | 1985 Ford F150
Help with seeing the video off my Pyle PLDN74BTI
bypass parking brake w/ no switch just codes for pyle pldn74bti car player
Jul 23, 2012 | Pyle PLDN74BTI Car Video Player
It says you can use an mp3 player for this radio. but i cant figure out how. How can I use my mp3 for this radio?
It looks like this device will play mp3's written to a cdr just as files. I don't seem to see an input for a headphone OR line in.
Apr 01, 2010 | Pyle PLCD73M Car CD/ MP3 Player
Radio removal
check if there a small hole in each side of the radio, insert a small screw driver in each hole then pull the radio. If no holes , check you dash if there a knobs for a/c remove the knobs there is a nuts hidden under it.
Jun 11, 2009 | 1995 Plymouth Grand Voyager
Safety 1st pink corvette
Below the radio is a panel held on by two knobs labelled "driver" and "passenger." Unscrew these knobs to get to the radio battery cover. Remove the battery cover with a phillips screwdriver and replace the batteries.
Aug 05, 2008 | Toys
Safety 1st yellow corvette
May 15, 2008 | 2004 Chevrolet Corvette
PARTS
Pyle does not sell parts for their units. What kind of part is it? You might be able to find a generic replacement...
Oct 15, 2007 | Pyle PLBINDV7 Car DVD Player
PLEASE HELP!!!
The Amp stays on because you have a constant 12V to the Remote.
If your stereo remote is no longer working then run a wire from a 12 volt source that turns on and off with your ignition something like your radio fuse in the vehicle fuse box.
As far as the Bass Knob if it is connected properly and still not working check the line for wire kinks or cuts that may have happened during installation if you cant find any problems you can get a universal bass knob that plugs via your RCA cables for under 20 bucks.
Hope this gives u some ideas.
May 05, 2007 | Pyle PLA2480 Car Audio Amplifier
Pyle PLR22MPF AM/FM-MPX MP3 Playback with USB/SD/AUX-In Logo
217 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
