Question about Motorola Mobility RAZR V3
No Service I have not had any service or connection for my phone for almost 24 hours. It has a fully charged battery and am near towers, but the phone still says no service. How can I fix this? Please help!
    Brigadier General:
  • 7,752 Answers
Your internal antenna must be faulty so you should take the phone and have it check by a mobile service center technician.
Posted on Feb 22, 2008
I have a 65hp suzuki outboard motor wont start just makes clicking noise and tilt aint working now motor was running season before
try installing a fully charged battery or charge the battery for 24 hours then jump start the boat from a car
Jun 24, 2014 | Suzuki Service Manual, 2 - 65 HP Outboards...
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
I fully charge the phone but within 48 hours,even without using it, have to charge it again
Don't panic this is quite normal.
Even when you are not using the phone it is still on and actively connected to your service network. Therefore using battery power.
Actually to get 48 hours from your handset is very good.
Normally you would have to re-charge the 81xx series at least every 24 hours.
I was charging mine every 12-14 hours.
Jul 27, 2010 | RIM BlackBerry Pearl 8100
Battery not charging
Hello.
Here are two:
Motorola Service Centre (Tamil Nadu, Chennai )
Shop No. 2, Door - 24, New - 30, Balfour Appartments, Balfour Road, (Near Kellys Corner) Kilpauk, Chennai - 600010
Operating Hours : Mon-Sat 10.00-19.00
Phone : 044-42128393
Email : tnagar@accordccs.com
Motorola Service Centre (Tamil Nadu, Chennai)
G-7, Ground Floor, 100, Apollo Dubai Plaza, Mahalingapuram Main Road, Nungambakkam, Chennai - 600 034
Phone : 044-42125180
Email : kodambakkam@accordccs.com
Hope this helps.
May 08, 2010 | Motorola Mobility RAZR V3
Tuesday I dropped my Motorola Rival in to a thing of water on my phone, it was in it's case. I took the back off and the battery out and placed the rest of the phone in rice. It seemed to work fine in the...
there might be water blog near battery connector or near charging section.kindly wash your phone with petrolium liquid & rehot with blower .don,t try this your self .kindly visit any service shop near by you.
Apr 08, 2010 | Motorola Mobility Rival A455 Cell Phone
How to repair a lost signal cellphone
do a master rest, if that doesnt work, make sure it is not a service provider problem, so in other words check that other sim cards work if it is an unlocked phone.
if they dont work either then the phone sounds like it has a software problem. u can reinstall the software i think online, otherwise take it to a repair shop and if its below say $50 its prolly worth getting fixed, but since they are only 150 new anyway, work out if its worth it or not.
May 05, 2009 | Nokia 6300 Cellular Phone
Battery last for about 1 day only
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
thank u rate me!!!
Feb 07, 2009 | Sony Ericsson W910i Cellular Phone
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Charging new phone
it wont harm your phone they just recomend 24 hours to make sure the bat is ok and that it gets fully charged but remember to let your bat go totally flat from time to time this will prolong the life of your battery as it does them no good just keep topping it up so i sugest to let it go totally flat say once a month this will keep your battery lasting longer between charge hope this helps
Oct 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
