Question about Xerox DocuPrint N17 Laser Printer
Printer won't print
Printer says ready, but does not print
    President:
  • 2,072 Answers
Have you first of all just turned the printer off and restarted it?
I assume you have, but just asking as a starting point.
Not sure how you are running it, so I will assume your running it via a ethernet connection.
Now where to start LOL.
1. Do you know the machine IP address? If so log into your browser, Internet Explorer, firefox,etc and enter the IP address into the address window and see if the printer information comes up. Also try and ping the printer. If that is not successful,
2. Check and or change the network cable to see if it comes on. You can look at the port on the back of the printer to see if the small green light goes on and off when you plug and unplug the network cable. If it is not on, suspect either a bad wall jack or cable connector.
3. On the printer, check the connectivity or network settings. Look under the IP settings, make sure it is not set to Auto. If it is, then the machine has most likely assigned itself a new IP address. If thats the case, if you have a configuration report from when the printer was set up, change the DCHP setting to manual or static, then re enter the IP address. You can also find the IP address assigned by looking into the printer properties, ports and see the IP address in the port assigned to the printer.
4. You can try running it on a USB cable, if you or a laptop is close enough to the printer. That way you can confirm a network or addressing problem. I will say, if there is a problem with in the printer, most of the time it will give you a fault code, and those printers are very stable when it comes to the NIC and other circiut boards, if it says ready, I very seriously doubt the printer itself is at issue.
5. You may have a bad router, someone turned on a firewall that is blocking the printer.
I suspect in order, an addressing issue, IP address related, or a bad cable.
let me know ok. Or ask if your not sure what to do.
Posted on Feb 22, 2008
My dell 3100cn won't print, even though it says the printer is ready
look inside of printer.see if something is pulled or unpluged. see if there is ink and paper inside.
Jun 20, 2013 | Dell 3100cn Laser Printer
Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Nov 05, 2012 | Alps MD 1000 Thermal Printer
Printer is paused all the time
Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
My computer says the printer is ready to print but when you try to print it won,t print and stores the document for printing later.
try to restart the print spooler from services.msc
start>run>services.msc look for print spooler then restart it
see if that helps
Mar 24, 2011 | Dell 725 InkJet Printer
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Xerox DocuPrint N17 Laser Printer Logo
217 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
