Question about Arris SURFboard SB5120 Modem
I have been with Comcast for 6 years. Leasing their SB5120 modem for 3-4 years, no problem. Then bought one myself and no problem for 2 years with Negtar wireless router. For the past few days, it started to have problem - only light up to receive, no send or internet lights lit. Please advise. Thank you.
  • 10 Answers
Generally a wireing issue or signal issue i assume by this time you have it fixed by the date. you can check 192.168.100.1 in a web browser and it should show the signals. if recieve is flashing then the downstream is either out of range or something else. it wont go to upstream until it locks onto downstream first.
Posted on Aug 18, 2010
I recently purchased a Netgear N600 Wireless router connected to my Comcast Motorola Surfboard SB5120 modem. I have a Comcast plan of 20 Mbps but through www.speedtest.net am consistently getting 8 Mbps...
I think its the modem that you need to upgrade. Comcast is already running on DOCSIS 3.0 system. The SB5120 modem that you have is a DOCSIS 2.0 modem. You may need to have your modem replaced with a DOCSIS 3.0 modem like the Motorola SB6120.
Aug 31, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Is the average life span of the motorola cabble modem 5120 7 years?
I just spoke to comcast and they suggested three years isn't unusual for this modem to start having issues.
Jun 17, 2010 | Arris SURFboard SB5120 Modem
I have comcast and i purchased the surfboard so that i could play use the internet for my xbox in my room. There is another modem on rent from comcast a touchstone telephony modem which provides internet...
u need a router to share internet connection, not 2 modems, from the way your explaining it im going to assume you just bought the modem went home and plugged it up, Well.. thats not going to work , your modem needs to be registered with the network your trying to access(comcast)
I’m happy to help further over the phone at https://www.6ya.com/expert/leon_509b29b7b5b43b5e
Jul 13, 2009 | Arris SURFboard SB5120 Modem
Port Forward on Comcast Motorola SB5120
Are you just using a modem and NO router? This modem has no NAT so there is no way to open ports.
Jul 09, 2009 | Arris SURFboard SB5120 Modem
Internet connection issue. Is it setup or internet service
The problem would be comcast. Your connections are setup correctly. The modems do not control the internet traffic flow, they are made to produce maximum flow.
If more people use the internet, the less flow it will have.
Check all internet options settings, and make sure EVERTHING is set to automatic
Jun 06, 2009 | Arris SURFboard SB5120 Modem
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Comcast modem
the light is flashing because your modem is working.
Dec 05, 2008 | Arris SURFboard SB5120 Modem
Loss of internet connection
Sounds like a switch before the signal gets to your house. Modems usually don't go out intermittently unless they are overheating. Is the modem in a ventilated area where it can get some air? An alternate is to borrow a modem from a friend to test it. Usually one of your niehbors will have the same service and the same modem. I had my surfboard (from comcast) for 5 years and it was solid as a rock, the spotty services was always at the Comcast switches (at the street or the nearest hub.
Hope this helps
Jun 13, 2008 | Arris SURFboard SB5120 Modem
Arris SURFboard SB5120 Modem Logo
227 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
jimmy Leo
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
