Question about Sony Playstation 3 (PS3) Console
Disc stuck in console seems to be a white plastic object in the middle of doorway stopping disc from lifting up to push it out/
  • 53 Answers
Open the ps3 or find something to take it out manually?
Posted on Feb 08, 2010
When i turn on the power, the wii doorway is lit blue nonstop & the disc won't eject when i press the ejection button. Please help!!
Did you lodge more then one disc in? Are there any foreign objects lodged in the disc tray? If both of these are false then the motor that spit out the disc is most likely broken. Your best bet is to call Nintendo support and see if they will repair it for you.
Mar 03, 2011 | Nintendo Wii Console
Game disc stuck in the Wii console
please goto the following link to fix your issue with your wii its the best solution I feel to fixing you wii.
http://www.somelifeblog.com/2008/06/nintendo-wii-dvd-drive-repair-guide.html
Aug 10, 2008 | Nintendo Wii Console
My Sega Saturn is acting weird...
try cleaning the glass laser eye with rubbing alcohol and cotton swab. This should fix the problem
Jul 18, 2009 | Sega Saturn Console
Kids stuck multiple discs in wii console. Anybody have any ideas on how to fix
Hi!
  1. Disconnect the drive.
  2. Open up the screws.
  3. You will now be able to see the white plastic mechanism on your right side and the wheel connected to the motor.
  4. Turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
  5. You will see the disc coming out while you are turning the wheel.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Feb 28, 2009 | Nintendo Wii Console
Wont eject game disc
From a previous FixYa member:
"I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel."
Dec 29, 2008 | Nintendo Wii Console
System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Playstation 2
IF THE DISC IS NOT BEING READ THEN THERE IS SOMETHING WRONG WITH THE LENS INSIDE THE PS2. IF IT IS BEING REA THEN TRY OPENING THE PS2 TAKE OF THE TOP. LOCATE THE TRAY COVER AND THERE IS A WHITE OBJECT IN THE MIDDLE, TRY SPINING IT. IF IT DOSEN'T MOVE THEN PLAY WITH IT UNTIL ITS LOOSE. ThEN TRY PLUGIN BACK THE PS2 AND INSERTING A GAME (DO NOT PUT THE TOP BACK ON) INSERT THE GAME AND SEE IF THE WHITE OBJECT IS TURNING WHEN THE DISC IS READING..
IF IT IS THEN THE DISC IS SPIINNING,
HOPE IT WORKS FOR U.
Dec 27, 2007 | Sony PlayStation 2 Slimline Console
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Wii console will not eject disk
Nov 25, 2007 | Nintendo Wii Console
DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Oct 15, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Sony Playstation 3 (PS3) Console Logo
109 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
