Question about Samsung SRP 350 Thermal Printer
I want to add the printer to my computer but i need the driver for an xp
  • Samsung Master
  • 12,061 Answers
Have a Windows XP computer and need to connect the X1190 to it. Need help please and I don't have a disc
The problem with XP is that its not support by any new printers. However, you may be able to use the universal HP PLC5 driver to run the Lexmark.. According to Lexmark windows XP is a supported OS for this printer. Go to the Lexmark site, support and download the driver. Here is the link
support lexmark com
Advanced Business Computers specializes in printer copier network support and maintenance.
Printer Repair Service in Miami and Fort Lauderdale FL
Oct 09, 2015 | Lexmark X Office Equipment & Supplies
I recently acquired an NEC SuperScript 1260 laser printer but I need an adapter cable so it will work off my computer (Vista). I need a pin connector for the printer on one end and USB for computer. The...
The NEC SuperScript 1260 has a parallel printer port. So you would need a parallel to usb adapter. These aren't very expensive; depending on the brand and length you'll pay between $8 and $15. See https://www.amazon.com/TRENDnet-Parallel-Converter-10-6-10-9-TU-P1284/dp/B0007T27HS or https://www.amazon.com/Sabrent-Parallel-Printer-Adapter-CB-CN36/dp/B00IDU0T1Y Alternatively, if you have a desktop, you can find a PCI or PCI-e add-on card with a parallel port, depending on the slots available in the system. These will be closer to $20 to $30. Then you need a standard parallel printer cable. Many computer parts sites, including Amazon.com, will have both.
A bigger problem may be the printer drivers. NEC did not update the drivers after Windows XP. (Some XP drivers will work under Vista.) NEC doesn't supply the drivers on their site: https://support.necam.com/Printers/Drivers/ . They refer you to the original driver CD that came with the printer. A few sites may have these drivers online. However, I haven't seen a link to a known trust-worthy site with the XP driver.
I hope this helps. Please add a comment if you need more information.
Sep 15, 2017 | NEC SuperScript 1260 Laser Printer
Want to install printer
If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
By default, Windows XP and Vista already has the generic driver installed.
However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
Thank you and good luck!
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
Printer status reads "printer offline"
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
Sep 06, 2017 | HP OfficeJet 7310 All-In-One InkJet...
Windows xp printer driver for Oki 320
Install an IBM Proprinter III driver. This driver is built into your Windows system and can be found in the Add Printer Wizard.
the computer will install that driver and it will make this unit compatible with windows xp
Oct 07, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Printer does not print
Did you install the proper drivers ?
Sep 13, 2009 | HP DeskJet 3820 InkJet Printer
I WANT MY EPSON LX-300+ INSTTALE TO MY COMPUTER
This printer needs a parallel port only. And if youre using xp os just make add printer and it will just add this printer, driver is almost ready. If it ask for driver just insert the winxp installer cd.
hope this helps
Apr 28, 2009 | Epson LX-300 Matrix Printer
Need to reinstall print 6988
If you're on XP, download HP Deskjet Basic Feature Software/Driver and then install this software.
Next, go to the "Printers and Faxes" part of the XP control panel and add the printer. Unless the printer has its own server (very unlikely for home use), then even if it is installed on a wired or wireless network, you need to add it as a local printer (again this should be done even if you have it connected to your local network), then add the printer. You may need to add a new port for the networked printer.
I hope this helps.
Mike
Jan 17, 2009 | HP DeskJet 6988 Printer
Add Printer
The Z22 does not appear on Lexmarks vista compatability list and so there is no specific vista driver.
There is a driver for Windows XP which you could try
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=227:1:0:0:0:0
Select Z22 as printer model and search
then choose windows XP from the list of operating systems
Nov 23, 2008 | Office Equipment & Supplies
Panasonic kx-131/330 Fax Printer Vista Driver
I think it's highly unlikely there's a Vista Driver. Does the fax have a USB Port?
Nov 04, 2008 | Panasonic KX-FM106 Plain Paper Thermal Fax
Samsung SRP 350 Thermal Printer Logo
306 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
