RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Feb 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I plug in the cable cord - RCA D52W20 52" Rear Projection HDTV-Ready Television
electronic & computer repair& servicre
Level 3:
  • RCA Master 12,061 Answers
  • Posted on Feb 08, 2010
RCA Master
Level 3:
Answers
12061
Questions
0
Helped
4008175
Points
36390
It goes into the Antenna Socket, usually at rear, you may need an adapter, to convert it to a Belling-Lee fitting, if the cable has a thread on it..
2answers
No display and dial tone on panasonic KX-T7730
Check cable from the phone jack both ends and see if its plugged in. Also, check power cord if plugged in to the power source.
I have a 42 inch maxent but i dont know where to plug my cable cord because i have a comcast box and theres no where in the t.v to plug my cable cord
If your comcast box has video (yellow), audio R (Red), audio L (White) out, just connect RC cables to the input of the TV at video, audio-in RC Jacks. If your comcast box has only RF out, buy one RF to audio-video converter and then connect these to the TV.
2helpful
3answers
I need to know where to plug the big yellow phone cord. One end goes in the top plug in the back of the router and where does the other end go? In the back of the motorola motem? What else is supposed to...
The cord you are referring to is a CAT5 network cable. The color isn't important, but they usually ship the routers with color cords to help with the installation. Typically you would have the following setup:
1. A CAT5 network cable that runs from your broadband modem TO your Belkin Wireless Router in the "Internet" port. (Port "a" in the diagram)
2. Now plug another CAT5 network cable in to the back of your computer's Network Interface Cord TO one of the remaining ports on your Belkin Wireless (Any of the port "b" in the diagram).
However, you will need to run the configuration software that come with your router.
Please let me know if I can further assist you.
Regards,
KYTechnology
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Hello i am having probelms with my Belkin g basic router it has wireless and it works but when i connect it to my computer it does not it says it can't find or something but if i plug in my other box that...
It's sounds like you're getting your cords mixed up. The modem (the box from your company that provides internet) needs it's power cord plugged in, a phone cord or a cable cord plugged in, and an ethernet (LAN) cord plugged into it. The power cord will plug into the wall obviously, the phone cord or cable cord will be coming out of the wall obviously, but the Ethernet (LAN) cord will plug into your computer or a router. A router in your case. So the Ethernet cord from your modem (box that came from you company that provides internet) will plug into the router in the specific slot that says Internet or Modem connection. Now you need another Ethernet cord to go from your router to your computer. Try to plug the cord that goes from the router to the computer into the 4 different ports on the router until one of them works, you'll have to give it about a min to check each one. If that doesn't fix it then you need to make sure your LAN card is being read correctly and installed correctly, best way to do this is to go to Start > Control Panel > Device Manager and look at Network Adapters. If there is a Red X next to a conenction, right+click the conenction and tell it to enable, or update drivers.
2answers
How to setup xbox live
Hello there
No problem, in just a few steps you too will be online and ready to go.
Ethernet Cable
With your Xbox 360 turned off unplug the ethernet cable from the back of your Xbox.
Xbox 360 Power Cord
Next unplug the Xbox 360 power cord from the back of the Xbox 360.
Unplug ethernet cable and power cord from the modem. Wait for about 1 minute and then plug ethernet cable back into the modem.
Now you need to plug other end of the ethernet cable into the back of the Xbox 360.
Plug the modem power cord back into your modem , wait for lights to light up on your modem (this can take up to a minute).
The last step is to plug the Xbox power cord into the back of the Xbox, turn it on and you are ready to go.
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Monitor
Monitors need power cords to function, & there is nowhere near enough power in the data cable to power the monitor. So, it sounds like the power cable got pulled out somehow and is now lying on the floor. The power cable will be a small plug like you have on a radio or other similar devices instead of the standard sized plug that older monitors have. Once you plug the power cord back in, it should be fine.
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
