Question about Garmin StreetPilot c550 GPS Receiver
My gps is not turning on at all. I even pushed
My gps is not turning on at all. I even pushed the reset button and nothing. I let it sit for almost a day unpluged then plugged it into my computer and nothing. It is a Garmin c550
  • 12,061 Answers
Hmmm I think your battery is worth having a look at. They often go bad for no apparent reason.
Posted on Feb 08, 2010
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
I cannot get my garmin 1490 gps to even turn on using the button even when i plug it into my computer, is they a reset button i can push
Your unit may be completely dead tyr cahrging it in the vehicle using the cord provided, some USB ports wont have enough power to charge or keep the unit on.
Hope this helps!
Feb 11, 2011 | Garmin nuvi 1490T GPS Receiver
I cannot even get the device to turn on. The light on top comes on when I have had it plugged in to fully charge but it will not turn on. I have also tried to reset and still nothing. Is it completely...
if the battery has been completely flat, you need to press and hold the on button for a couple of seconds as opposed to just a quick push for normal start up. It will do a complete startup
Oct 05, 2010 | Tomtom ONE GPS Receiver
My tom tom sat nav wont turn on even when plugged in charger whats the problem?
hi try a soft reset, first make sure your battery is full. if you use a sd card, remove it. push reset button on bottomside of your tomtom, its in the middle next to "reset" push it with a small pin, paperclip or something, for at least 15 seconds. after that push on/off button for minimum 5 seconds. if used push back sd card. good luck
Feb 19, 2010 | Tomtom GO 700 GPS Receiver
My gps unit got stuck on a location and I turned it off and it won't turn back on I've held the power button down for a while but nothing
Look in the back of the unit for a reset button, this will be a small tiny button or maybe a small hole in the back with the word reset on it. If it is the hole then use a paper clip to to push the reset button. Note power must be on to reset the unit.
Jan 14, 2010 | Panasonic Navigon 5100
My tomtom 720 will not turn on
push the reset button for 15 second then push on/off button for 5 second, it will start now
Oct 31, 2009 | Tomtom GO 720 GPS Receiver
Garmin Nuvi won't turn on
See if you can find the reset button on the unit and push it while the unit is on. On newer units the reset button is on the back, but on older units it may have a faceplate cover around the edge of the screen you have to remove and the reset button is sometimes located under the faceplate...this may work
Jan 01, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi 200 wont turn back on
Our Garmin didn't turn on. We unplugged it, pushed the reset button on the bottom and then plugged it in again and it WORKED
Aug 02, 2008 | Garmin nuvi 200W GPS Receiver
Tom Tom One Doesn't Turn on
in that case you will have to take off 4 screws on back the navigation system
easily take the back piece apart and unplug the battery wait couple a seconds then plug it back
it should work
Apr 20, 2007 | Tomtom ONE GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
379 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
