Question about Microwave Ovens
I have a Thermador Professional Dual Fuel Range PD486GEBS/04 When I came in from dropping kids off from school the blue heating light was blinking 3 times in a row. I turned some of the knobs and now I'm getting a different code. Oven light 1x, heating light 2x. The codes are not continuous at this point. I can only get them to appear if I attempt to turn on and then choose a temperature. Neither the small or large oven appears to be working.
  • 1 more comment
  • jkim365 Feb 08, 2010
    I would like a second opinion. I'm going to have to hire someone and this is going to be very expensive
    Thank you. The first response also mentioned needing to replace the board.
  • jkim365 Feb 09, 2010
    Thank you. Do you think i have to worry about electric shock (the warning at the beginning of the manual mentions this)?
  • 619 Answers
Oven sensor seems to be bad. this is approx. 65.00 plus shipping from most online parts stores.
Posted on Feb 10, 2010
  • 8,220 Answers
Sensor shorted. Locate the oven sensor and replace it. Page 41 of this old manual explains how the codes work, from the looks of it this is a fairly easy fix.
Posted on Feb 09, 2010
  • Dan Webster
    Dan Webster Feb 09, 2010
    Get a meter and yank out the sensor, Check it for continuity and if the sensor is shorted to chassis. I have some old training films which show how to check a sensor HERE. An older Thermador range manual HERE
  • 421 Answers
Hi, Can't see the other reply but sadly this usually means that the oven control board may need replacing. However, find a local appliance shop that can come out and run some tests before buying a new board. It could be something more simple that will save you some money.
Posted on Feb 08, 2010
  • 3,741 Answers
The problem is a bad control board. Thermador part number you need is 499845. Unfortunately, the boards are located on the back of the unit, so the range will have to be slid out to replace it. the hardest part about doing the repair is going to be getting to the board. It's mounted on the back wall behind the two lower panels. This means you'll have to slide the unit out to do the repair, and this unit weighs well over 600lbs. Some servicers use sliders which can be slid under the feet, where others have air-sleds that make the job many times easier.
Once you get to the board it's just a matter of swapping the wires.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Kitchen Aid microwave over will not heat
Common cause of this problem is transformer fuse blown.check the fuse.if fuse is ok, then replace magnetron
Mar 02, 2015 | KitchenAid Microwave Ovens
Thermador opion 3 micrawave does not work
First if it has a turntable and everything lights up etc, does the table move or not? If it does but no heat/cook possible inverter board or even the Magnetron unit.
If table does not turn it may be a safety switch located in the unit that is not engaged (have to get at from inside unit).
Nov 04, 2012 | Thermador MBBS Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
Thermador microwave stops heating after a few seconds
HI.Did the breaker tripped off when it suddenly stop during operation.Can you. Check if motor is working too.Oven has magnetron capabale of producing heat to the system.Now if the motor is working light is ON.Then the problem is with the magnetron.A square-sized accesory inside the oven with color silver on it.If motor is working then the heating element has theproblem which needs to be replaced.
Jul 22, 2011 | Thermador Microwave Ovens
Daewoo dual heating system microwave KOC-873TSL is not heating/ cooking. What could the problem be?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Feb 22, 2011 | Daewoo Microwave Ovens
GE model J KP85B0A3BB over range will not heat up. Both control panels for microwave and range work, interior light comes on when door opens, and glass plate will turn...
The most likely problem is the magnetron, it works with the high voltage capacitor and diode which can be a factor. The three work together to generate the high voltage that heats the food. If the repairs are done by a professional the cost will be high when you consider parts and labor.
Feb 09, 2011 | General Electric Microwave Oven
Everything is working, but no heat. lights come on, turntable turns, fans run, but no heat
Normally this would indicate that the diode in the power supply for the Magnetron (microwave radiation emitter) has failed. I would recommend that the unit be serviced by a professional in this area, or disposed of because of the following:
1 The power supply for Magnetron Tube the produces thousands of volts and can produce a lethal shock even though the machine is turned off and unplugged. Really, I'm not kidding.
2 Working on a Microwave Oven can expose you to high levels of Radiation which can immediately
Damage internal organs.
That said, there is another even better reason.
3 Microwave Ovens are now very inexpensive to replace.
Even though I personally know how to fix them, I can't be bothered.
I hope I have been of help
Happy New Year,
Best, Mark
Jan 01, 2011 | Samsung SMH9187 Microwave Oven
Did Thermador range model ESC30 require 240 volts?
I searched this model,but all i could figure out is that it requires a 3-wire 40 amp cord .wich i believe is used for 240 volt applications.sorry couldnt be more help
Oct 11, 2010 | Thermador Microwave Ovens
Thermador RES 30 range. I need wiring color and connection assistance to the display assy. I sent the display in for repair and now I am re-installing it. I thought I marked the connections down...
That is proprietary Thermador information, they are the only ones that can provide that. Was it Thermador that you sent the display into for repairs? If so they should definitely be able to give you the information you need. Do you need their phone number?
Please let me know and I can definitely help, thanks
Tim
Sep 10, 2010 | Thermador Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
