Question about JVC 12 DISC RF CHANGER MP3
I own a JVC KS-RF150 12 disc cd player,all of a sudden there is no power to the unit,checked all the interior fuses,radio is working fine and all connections to the unit are secure.Tried to reset it and still no power....HELP!!!!
    President:
  • 1,768 Answers
Question ?
Are you using the remote to accomplish the power on
Check the fuses again it may be that the fuse in broken
2. To check some fuses you will need a meter to see if they Ohms reading if so the fuse is bad. Usually a fuse will read infinity if it good.
2. there may be a coupling capacitor on the main board that has become weak in the power section of the circuit board,
3. Also check all connector on the main board they could be intermittently connected
4. if you have power then a connector may come disconnected such a the ribbon cable to the power switch.
5. there also may be a diode or led that has blown that is in line with the power switch will not allow power to the switch for the disc player.
6. Voltage check at these points will tell if you are getting dc power from the transformer to the switch.
Posted on Feb 09, 2010
I have a JVC in dash CD player its I think a sw68 one day I was mashing the search button repeatedly while searching for a song on my USB flash drive when all of a sudden it wouldn't turn.... Here's the...
I also had a JVC unit in my old car, unsure of the model. It was used prior to my purchase, like the car was, and the SEEK > button was the same way. It would kind of stick down/pressed in, and very rarely work, and most the time it DID work was when I wasn't even pressing any buttons. all other functions of the radio were still there but because the connection behind the SEEK > button was shot, I just spent next to nothing on another radio/cd player. it may depend however if your unit is new or an older one like mine. best of luck!
Jun 06, 2014 | Audio Players & Recorders
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
Is the JVC CH -X400 compatible with the KS-FX222E?
Hello
The devices you specified here; JVC-CH-X400 and JVC KS-FX222E are non-compactable.
May 26, 2011 | JVC CH-X400 12-Disc CD Changer
JVC KS F90 Radio cassette loses all settings when switched off
Your radio probably needs a constant live to retain the radio settings. It may be that your radio has 2 live wires. 1 live that operates the radio coming from the ignition and 1 coming from a constant live that just gives enough power to retain the memory settings.
If you are going long periods of not using the MGB I would disconnect the battery to stop the it draining. If your battery goes completely flat it will damage the battery
May 16, 2009 | JVC KS-F90 Cassette Player
RESET 2 compact disc charger CH-X350 JVC.
I have no solution but the same problem and wish to solve it asap.
Anyone would you please help
If anyone has a JVC 12 cd's changer CH-X350 and also had the same problem (radio says when you wish to hear cd's : Reset 2), would you please tell.
thanks.
Mar 13, 2009 | JVC CH-X350RF 12 CD Changer
JVC CD player won't turn on, but will eject CD and display time.
Make sure the red wire is still connected or make sure the red wire hasn't been severed. Also, check the fuses located in the engine compartment. The red wire connects accessory terminal in the fuse block. Also check the fuses in the cabin. This fuse box is typically located on the driver's side, at knee level, next to the door panel, and underneath the dashboard. As a last resort, the unit can be taken to an authorized or factory service center.
Dec 14, 2008 | JVC AM FM CD DET FACE CAR STEREO
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
JVC 12 DISC RF CHANGER MP3 Logo
535 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
