Question about Lisle Serpentine Belt Tool
Serpentine Belt Replacement 1998 Pontiac Bonneville, 3800 engine, the engine mount seems like it is in the way, does it have to be removed?
  • 1,675 Answers
Unfortunatley yes you will, i would advise taking a picture or doing a drawing of the routing of the belt, as to be honest it goes everywhere..lol, good luck
Posted on Feb 08, 2010
Crankshaft sensor
Here is a link to a how-to video, but he doesn't show you the first few steps, so, first, set parking brake, disconnect negative battery cable, raise and support vehicle. Remove passenger side wheel and then the inside splash guard in the wheel well. Remove serpentine drive belt, then remove the crank pulley. Watch the video for the rest.
crank shaft sensor replace 1998 Pontiac Bonneville 3800 motor p
Jul 30, 2014 | 1998 Buick LeSabre
Replace v-ribbed belt
Use a long wrench on the tensioner pully nut (located in the center of the pulley) Move the wrench to removed tension from the idler (this is spring loaded to maintain constant pressure on the belt) once that is done, the belt should be able to slid off the alternator pulley. With the belt removed from the pulleys, you will have to remove the engine mount bracket to be able to replace it. To do this first support the engine, then remove the bracket. You will then be able to remove the serpentine belt. Look under the hood for the belt routing diagram and re-install the belt, followed by the engine mount.
Feb 12, 2012 | 1998 Pontiac Bonneville
Need a routing diagram for a serpentine belt for a 98 Pontiac Bonneville V6 3800 Series 2
Go to this web site.
http://www.greatautohelp.com/How-To/Replace-3800-V6-Belt.html.
There is a good diagram of the belt routing.
Mar 21, 2011 | Pontiac Bonneville Cars & Trucks
How to change belt on a 98 pontiac bonniville
You are asking how to remove the serpentine belt on your 3800 engine ?
First, I would take several pictures so you know how it goes back on.
1) * You must have a special idle pulley tool. Take you tool and pry the idle pulley enough to remove belt, dispose of old belt.
2) Now place the new belt on the pulleys just as you see in the pictures you took or look at the diagram on the radiator support.
3) Pull the idle pulley again with your tool and put on the belt.
The idle pulley will put the tension in the belt.
Please let me know how it went.
Feb 08, 2010 | 1998 Pontiac Bonneville
Do i have to disconnect motor mount to replace my drive belt
Depends on the motor. If there is a mount on the passanger side that the belt goes around then yes. Don't fret though, easy to get around. Use a jack and a piece of wood on the oil pan to support the motor so you can remove the motor mount to remove the belt. Again, this is on SOME gm motors not all. On the others the mount isn't in the way at all.
Jan 24, 2010 | 1995 Pontiac Bonneville
Serpentine belt cant figure out how it goes on and it has a supercharger as well need the diagram
I have a 97 Bonneville, you have to undo the passenger side engine mount. No joke.
Apr 12, 2009 | 1994 Pontiac Bonneville
Lisle Serpentine Belt Tool Logo
160 people viewed this question
Top Lisle Hammering Experts
john h
steve morris
steve morris
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
