Question about HP Office Equipment & Supplies
My hp officejet 7590 will not grab the pages that I want to fax. How can I fix this proplem?
    President:
  • 3,085 Answers
Open up the doc feeder and clean the roller and pad with alcohol.
Posted on Feb 08, 2010
OfficeJet Pro 7590 cuts off last line
Check the format of paper.If it "letter"may have this problem.Change to "A4" and try again.
Oct 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Im having trouble scanning on the hp 7590 printer
Kindly reinstall your HP 7590 Printer to refresh and fix the error or corrupted files in your driver in order to run your device properly. Make sure also that the driver you install for your printer is support with your Current Operating system to minimize error and malfunction of the device.
Thanks
Jul 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper is not feeding into the top.
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from the computer.
It would either grab several pages at once, or not grab paper at all. The device was trying to work but had poor traction action. Not sure if that's the same issue you are facing, but if it is, this is what fixed my 7210: I purchased part number C7309-60091 which is the feed roller assembly, and part number C7309-60076 which is the separation pad from Encompass Parts, and replaced them. The ADF works great now. The HP Officejet 7210 had only 5,000 pages printed on it, so I chalked it up to our very dry atmosphere here.
Jul 10, 2009 | HP Officejet 7210 All-In-One InkJet...
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
My fax machine is pulling more than one sheet of what i am trying to fax at once how do i fix it?
This is a common problem with HP printers and faxes. There are feed rollers inside the units that "grab" the top page and pull it through. These rollers have a "cat tongue" surface, and as they wear down, they don't grab as delicately as they used to.
I know they are easy to replace on HP printers (about 30 seconds, just remove the paper tray, slide old roller out and replace) - HP all-in-ones I imagine are roughly the same.
Here is what they look like (in general):
http://www.perthprinterrepair.com.au/wp-content/uploads/2008/02/8100-roller-kits.jpg
Note that the above link is not the exact part you need, just an image so you know what to look for and don't spend $100 when you only need to spend $10 :)
Hope this helps - remember to rate :)
Oct 01, 2008 | HP Officejet 4315 All-in-One Printer
AUTOMATIC ORIGINALS FEEDER
I'm trying to print/fax several pages but the feeder doesn't "grab" the paper--basically nothing happens...BTW, mine is the HP Officejet Pro L7780 All-In-One.
Sep 10, 2008 | HP Officejet Pro L7680 All-In-One Printer
Will not grab documents
hi,
try this...
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time and while holding it, insert the power chord.
> a semifull reset would be done
> after that try to fax.
thanks and regards
agnel
Feb 26, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
53 people viewed this question
Seeker5211
Seeker5211
