Question about Mitsubishi WS-65909 65" Rear Projection Television
I have a Mitsubishi WS-65909 w/a steady blinking timer light. Steps I have tried to correct include: System reset for 10 seconds (after I left unplugged and disconnected from ALL attached components for 24 hrs.), Error Code OPERATIONAL CHECK (DEVICE+MENU) for 20 seconds with no change, pressed Power + Menu buttons simultaneously and held depressed for 20 seconds with no change, pressed Power + Display buttons simultaneously and held depressed for 20 seconds with no change, and removed DM Module to check for blown capacitors-all look fine. In fact, there are NO bulging capacitors on any of the 3 boards. Any assistance would be greatly appreciated.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Only one of two reasons for your problem--either the DM is bad OR:
These sets sometimes develop a problem with the front keyboard---micro switches in back of the plastic buttons can fail (reset one is common).
Remove front speaker grill and inspection plate behind it and follow the group of wires coming down from the front keyboard to the right top edge of the opening.
About 8 inches to the right you will find two plugs that are inline--they go to the keyboard--disconnect both and turn set on with REMOTE (remote receiver is behind the screen).
If the set now functions you have a bad micro switch on the keyboard (most likely the reset) and two choices---either leave the keyboard unplugged and just use the remote or remove entire screen and get at the circuit board and locate and replace defective micro switch.
Lots of people miss this as a possible choice--easy to do to either know it is the keyboard or not.
If set does not operate this way DM is bad regardless of how caps look.
SD TECHI have a Mitsubishi WS-65909 w/a steady blinking - 0d60ab8.jpg
Posted on Feb 08, 2010
Testimonial: "Thanks. I had found and tried the front control panel solution prior to your response but to no avail. Thanks for the help. Take care."
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
How do i locate the dm. the problem stated above is exactly whats going on. i get green blinking light steady with nothing else. someone also mentioned bypassing timer, and it will work?
toctallent,
The DM board is located in the sheilded box to the left side of the unit looking from the rear. You have to disassemble most of the unit to get to it. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem and where to get a board repair kit to repair the unit. The same company has excellent installation instructions.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 27, 2011 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Timer light binking green
U have a DM problem CAPs burned out. download repair manual for your TV.
Jun 30, 2009 | Mitsubishi WS-65909 65" Rear Projection...
We have the dreaded blinking green "timer" light after we unplugged the WS - 65909. We can't get it to reset according to the owner's guide instructions.
The Digital module must be repaired. It is not booting up. When first plugged in the LED in that set will blink for 70 to 90 seconds. That is the amount of time it takes for the digital module to boot up. If it continues to blink past that time the module is belly up and needs to have some capacitors changed in it. Most reputable shops can do this in your home and average cost is between $150 and $250 depending on where you live.
Jun 11, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Will not stay on., Automatically turns off.
Try pressing in both the menu and device/input buttons in together on the front of the set and hold for 5 seconds to see if the led will blink a two digit error code such as 2 blinks then a pause then two more blinks followed by a pause which would indicate a 22 error. Then let me know what the blink code was if any.
May 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
1,022 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
