Question about Dual XDVD8181 Car Video Player
Extra Space Filler? PS2 hook up?
Couple of questions. First, where do i get the plastic thing that goes around the indash unit to cover up the extra space after instalation? Secondly, can i hook up a PS2 to the 7inch monitor Dual CD/DVD indash unit?
    Sergeant:
  • 306 Answers
Try any audio shop . its called an install kit. and as long as your unit has a/v input you can wire the ps2 right to it
Posted on Feb 08, 2010
Hard drive failure replacement what kind of hard drive can it be upgraded and have more memory
sorry but you need to contact the manufacturer and ask them if it can be done .
Apr 08, 2015 | Home Security
How do i hook up a battery for dyna wide glide 2010
Wow, my 2000 wide glide only had two, so I'm afraid you should not trust anyone but the dealer. Just give them a call and maybe they will answer your question. If they tell you to bring it in call a different dealer.
Feb 18, 2015 | 2010 Harley Davidson FXDWG Dyna Wide Glide
Where do you hook up the extra wire from the negative battery cable on 1999 chevy silverado
Extra Wire !
Small wire coming out of the neg terminal at the battery?
Usually goes to a sheet metal screw & fastened to the radiator
support sheet metal or over to the fender lip
Look over a couple similar vehicles on your lunch break
Sep 24, 2011 | 1999 Chevrolet Silverado 1500
What do I need to do to remove the battery from my 2008 G37s? I tried moving cables and the fuse box around, it's not enough room to remove it.
You'll have to remove the covering above it (wiper motor covering) to gain that little more extra space to get it out. It's a really tight fit. Hope this works for you.
Feb 17, 2011 | 2008 Infiniti G37
Need to remove door panel drivers door bonneville 1999. my goal to replace outside mirror. thank you,
Door panels are about the same they have always been.
You first remove the things attached, like handles, etc.
Most have screws, either recessed or covered by plastic plugs.
Door handle may have spring clip that requires a hook or special tool for, but you can improvise. Just push panel in to get a better look around handle shaft.
Once you have all the extra stuff off, then pop all the little plactic or metal clips around the front, back and bottom edges. It helps to use something a little wide, to not scratch or break panel. Each clip snaps into hole.
But the top is different, and hooks over the metal door inner shell. It has to be lifted upwards, after unscrewing door lock button, if there is one. The bottom of the panel has to be held out enough to clear handle shafts as you lift up.
Apr 20, 2010 | 1999 Pontiac Bonneville
What is the purpose of the usb ports of my ps2
Kind of the same purpose the large section at the back is empty, if you remove the plastic cover on the larger units that is. SONY had plans to expand the PS2 so that the PS3 was actually just an extra connection, (sort of what project natal will be to Xbox360) but as is the way of the wprld a good idea left behind due to bugger and better things. Apparently there were a style of controller you could use in the USB port to enable four players without a multi tap, but i feel that is a gamers urban legend. I hope this helped. Thanks.
Apr 17, 2010 | Sony PlayStation 2 (PS2) Console
I'm trying to play Kingdom Hearts on my PS2 however when I jump up onto one of the towers where you choose to get get a power it freezes on me. I can move the hand so it goes from yes or no, but it won't...
For all Forms except Wisdom, Sora wields dual Keyblades. To customize which
Keyblade is added for each Form, go to the Items menu and choose Sora.
The top choices are:
Keyblade (red)
Brave (blue)
Master (blue)
Final (blue)
Keyblade determines your default Keyblade.
Brave detrmines the extra Keyblade in Brave Form.
Master determines the extra Keyblade in Master Form.
Final determines the extra Keyblade in Final Form.
Note that you cannot equip the same Keyblade to two different Forms, i.e. each
Form must have its own extra.
As returners from the original Kingdom Hearts, both the Oathkeeper and Oblivion
Keyblades have attached abilities that can help your forms. See the Extras
section for more details.
Dec 03, 2009 | Sony PlayStation 2 (PS2) Console
I am having problems with an extra monitor
I would say this will be resolution problem.
Lower the resolution on the secondary monitor and try again.
let me know how it goes.
Dec 02, 2009 | Microsoft Windows XP Professional
Phenom
Nope, that did'nt work either. The answer to the other question is yes ,I paid 3 times. Is there a way around that?
Jul 24, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Dual XDVD8181 Car Video Player Logo
74 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
