Question about Vacuums
Not sucking at full power. lines are clear. don't understand.
  • caboose8 Feb 22, 2008
    I have a golden retriever - need I say more? I cleaned my rugs until about midnight. Did not put water on the kitchen floor to clean it out - now I have a serious problem - it does not such up. I used my steamer to try and loosen up the hair etc - I was able to get some but there must be a spot at the top - is there a way I can take the front clear section apart?
It is the hoover steamvac - I really vacuumed before I used it - but with pets, I needed to clean the rugs. I also have a steamer and that loosened some of the hair or whatever along the sides of the front panel - the steam/water went up into the front part but the machine still would not pick up the water off the floor.
Posted on Feb 23, 2008
  • 126 Answers
It would help to know what brand of machine you have and if it's a vacuum cleaner or a carpet shampooer.(It sounds like a shampooer.)
Posted on Feb 22, 2008
Precision model EL8802...hard to push, sits too low to carpet
An upright cleaner that is in good condition and working properly is always hard to push on loose laid carpet as it is designed to suck the carpet clear of the floor firmly against the mouth of the brush housing. This is so air is drawn through the carpet to aid dust removal and so the brushbar can make full contact with the carpet.
Jun 03, 2017 | Vacuums
The suction on my bissle 93Z6 isn't working. I can turn the vacuum cleaner on but only if the brush is engaged? Any helpful suggestions to troubleshooting the problem?
I am not sure I understand your question. If the problem is that the vacuum won't run without the carpet head, that is beyond my expertise. If the vacuum is on and there is no suction, there are only three possibilities: 1. There is a plug somewhere between the pick up point and the fan. 2. There is a hole somewhere between the pick up point and the fan (an air leak reduces the vacuum) or 3. The motor is running but the fan is not turning or has been damaged badly.
My son's Bissel lost suction when used to clean carpet, but was fine when doing hard floors. The plug was in the line between the brush and the point where the hose could be removed and connected to a wand to do hard floors. It is difficult to see a plug in this section of the line (it is hidden inside the head). I was able to use a stiff wire (with the vacuum off) to dislodge the plug. (I inserted the wire, poked and prodded the plug., turned the vacuum on and checked to see if it would suck out the plug and repeated until the plug finally cleared.)
My daughter's Bissel lost suction when something (I have no idea what!) abraded the line (short section of ribbed hose) close to the brush so that there was a major air leak. Being cheap, I disassembled it enough that I could wrap that section with electrician's vinyl tape to seal the leak.
I haven't had a vacuum where the fan became disconnected from the motor, but I have had fan destroyed. I had a leaf blower that could also be used as a vacuum. In vacuum mode everything that was sucked up passed through the fan. Unfortunately, it was a strong vacuum and would pick up small rocks. When a fan has lost most of its blades sucking rocks, it stops sucking anything! Most vacuum cleaners are designed so that debris can't get sucked into the fan, so this is the last thing to check. It requires significant disassembly to be able to see the fan and can be dangerous to turn on to observe its operation once exposed.
Jan 29, 2015 | Vacuums
How do I clear a blockage
Try removing your hose from the bag housing (pinch retaining ring and pull out) and re-inserting in reverse order. Turn the vacuum on and suck the clog into the bag. This will usually clear a clog from the hose. If the clog is in the power head (base), you can usually access it from the top side of the swivel neck or the orange access door on the bottom of the chassis.
Sep 23, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Solution tank not sucking water
Hi Arty5153. I'm sorry to hear you're machine isn't using the formula. I know how frustrating this must be.
I understand you did do some troubleshooting steps, but I want to provide you with a link to our complete list.
May 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
My bissell upright won't **** up the water, but the attachments will
Hey Maria, sorry to hear about the no suction.
Here's a quick link to troubleshooting steps to assist you.
Feb 02, 2013 | Bissell 8910 ProHeat Clear View Upright...
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
It seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Mar 12, 2010 | Hoover Tempo Widepath Upright Vacuum -...
I have no suction through the tube so unable to clean with attachments. Why?
Its plugged up. Remove hose from appliance, and see if the cleaner sucks. If so, pull hose in a straight line and push a broom handle through the hose to clear debrie. Re attatch hose and this should clear the blockage
Dec 04, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Vacuums Logo
176 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
