My Computer Logs in Then All My Icons Are Missing And My Task bar And My Task Manager I Think Is Disabled.
  • 2,517 Answers
Try these. Please restart your PC when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally & all the icon comeback like previous. If not & follow the same problem, then format the OS system and installed it again.
Thanks & waiting for your feedback
Posted on Feb 08, 2010
Taskbar and home icons are missing from msi u180 netbook, how do I restore
Try hitting ctrl and esc. You may have inadvertently hidden your task bar.
Apr 03, 2013 | MSI Computers & Internet
No start task bar in safe mode
It sounds like explorer.exe is being turned off. When you log in to Safe Mode hit Ctl+Alt+Del to bring the Task Manager and see if explorer.exe is running under Processes. If not, you can go to the Applications tab in Task Manager and click the New Task button and simply type in explorer.exe.
If this does not give you your Start Menu and Task Bar then you need to take your computer back to the repair service and have them fix it properly this time. Otherwise, you'll have to reinstall the operating system.
Jul 06, 2012 | Dell OptiPlex GX260 PC Desktop
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
My laptop is HP Compaq 6720s Volume, Power, and Network notification icons are missing from taskbar. They cannot be re-enabled from the Taskbar and Start Menu Properties as they are disabled or grayed out....
This is a simple fix in windows vista or windows 7. hit the keys CTRL+ALT+DELETE simultaneously and release. The screen that comes up click on Start Task Manager.
In the task manager window click on Processes Tab. Look for explorer.exe and highlight it and click End Process. Click Yes to stop it. When it is gone from the list, click the Applications tab and click on New Task. In the run box that pops up, type in explorer.exe and click OK or hit Enter. Once your task bar and icons repair look in the system tray area by the clock and the missing icons should now be there.
Apr 14, 2011 | HP Compaq 6720s Notebook
IM box will not appear
The system tray (in short: systray, nowadays also called taskbar notification area) is the icon strip normally located near the right end of the task bar, next to the clock.
Some Windows XP installations show a peculiar defect in that some systray icons disappear or, rather, do not appear, when the system is booted and the user logs on. The problem is even more prevalent on systems with autologon. The most frequently affected icons seem to be the speaker icon (sound volume) and the power/energy icon.
This has nothing to do with the hide inactive icons settings. The defect shows up when you don't have any icons set for hiding.
In any case, please make sure for now that you haven't activated that setting. Right-click the task bar, click on Properties, uncheck the last check box. You can reactivate it later if all other problems are identified or solved.
Check your Startup folder and the starter registry entries through Start, Run..., type: msconfig, press Enter, to check whether the programs are really started at system start, or use Task Manager (Ctrl + Shift + Esc) to see whether the processes are running.
Jul 03, 2010 | Yahoo Messenger
I HAVE A WINDOW XP HOME EDITION AND WHEN I START MY COMPUTER THE ONLY THING THAT COMES UP IS THE BACKGROUND. THERE ARE NO ICONS OR A BAR AT BOTTOM OF SCREEN.
the icons and the bar(task bar) at the bottom of the screen are enabled by the explorer.exe file
it starts automatically but in your case it is not starting
to start it when your computer starts and comes at the desktop, press alt+ctrl+delete button at the same time to bring up the task manager
when you do this a task manager shows up in a window
in task manager window click on file, it will be located on the top left portion on task manager
now click on "new task(run)"
this opens another window, in that window type
"explorer"
without the quotes "" and press enter
this will bring you icons and task bar at the bottom of the screen
Sep 29, 2009 | Computers & Internet
Black task bars
I would recommend you to install a application called TuneUp utilities which is a awesome software to restore your taskbars, broken desktops and missing files in windows operating system. Dont worry all your icons would be restored.
Sep 18, 2009 | HP Compaq FS7600 17" CRT Monitor
Icons and start upmenu bar absent
explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
Jun 08, 2009 | Computers & Internet
Desktop icons and task bar not showing just blue screen on login
Press Ctrl+Alt+Delete when you get to the desktop, when it comes up click on FILE then on NEW TASK (RUN), type EXPLORER.EXE and press enter, this should bring your icons and taskbar back.
Once you have them back, click START then RUN and type SFC /SCANNOW and press enter.
PS. Note the space between C and /
May 07, 2009 | Microsoft Windows XP Professional SP3 Full...
Desk top icons
Right Click the desktop, select "Sort By", select "Show Desktop Icons". Done!
Dec 06, 2008 | Dell Inspiron 2200 Notebook
21 people viewed this question
jasbo
jasbo
