I need a Kenwood Stylus N-74.
I have a Kennwood KD-38 R turntable. I need a Stylus N-74. Where can I find one? Or is there a replacement number available that will work? Thanks for your help!
    Brigadier General:
  • 8,546 Answers
There's a whole list of resources here, including one at Amazon for $16.73
http://www.retrevo.com/s/stylus+n-74
Or Radio Shack.
Posted on Feb 08, 2010
I have a Kenwood KD12R turntable. How do I set the arm and needle. I have a weight with an adjustable dial at the end of the arm and a separate anti skating dial on the base of the turntable? Regards -...
The weight should be set to the position recomended by the cartridge maker. Typically 1.5 to 2.5. If you don't know the makers setting, set it at 1.5 and work upwards. The stylus should track nicely in the record groove and not jump. But not too heavy as to cause rumble in the sound. Set the skate control low and again try the record out, if the stylus starts to skate accross the record increase the force. It's a case of experimentation with no fixed rules on these settings. Some records might need adjusments afterwards.
Feb 15, 2011 | Kenwood KD-291RC Turntable
I am looking for a new needle for a KD-2070 turntable and unsure of what kind to get?
The answer is on the cartridge. It should have a make or model number on it. You can type that into Google and the word stylus. You should find the correct type. Sometimes it's cheaper to buy a new cartridge and stylus together. You can then go for any type, as long it will fit on the headshell of the arm.
Jan 11, 2011 | Kenwood Audio Players & Recorders
Hi, I need help in finding cartridge and stylus for Kenwood KD40RB. Thanks ASR
You need not have to check for Kenwood but many cartridges are suitable to be fitted on to this model .
Please find help to fix them and choose a cartridge/stylus accordingly.
click on Stylus
Nov 25, 2010 | Kenwood KD-291RC Turntable
I have a kenwood full automatic turntable KD-67F ac 120v 10w 60hz. I dont know how to get the thing to work what else do i need? speekers? or other things if u could let me know it would be a great help
First of all you will need an amplifier, because a turntable has no sound power and its impedance needs to be balanced by a phono input, often found on a receiver or an amplifier. Then you will connect the speakers to the receiver or to the amplifier. I believe that a good start would to buy an old cheap stereo receiver, which has phono inputs, where you connect your kenwood turntable. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Kenwood KD-291RC Turntable
Kenwood turntable cover hinge replacement
Yes they can be replaced.
Contact the store you purchased it from or ask where they have repairs done. They should be able to order the parts for you.
Sep 11, 2009 | Kenwood KD-291RC Turntable
I,m trying to replace my kenwood KD 47F turntable V68 catridge & N68 needle stylus with an Audio technica set due to non availibility of N68 stylus in my home country- singapore. Audio technica...
hi, any cartridge are posible in every turntable as long the needle is available...the wiring is the same the position ,, but the only thing that im not sure is the sensetivity of the needle ..some are not good but some is compatible..u
Jun 30, 2009 | Kenwood KD-291RC Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Sep 18, 2008 | Kenwood KD-291RC Turntable
Kenwood KD-76F Turntable Problem
There is an adjustment in the postion sensor switch of the tone arm located under the support housing. BE VERY CAREFULL in lifting or fliping the unit over. If you can lock the arm in postion please do so before proceding. There may be some dust in a optical sensor or the postion sensor switch may be loose and just need repostioning to the correct location. If your not technicaly inclinded I suggest a strong blast of air in this area may solve your dilemma, possibilty hair dryer(NO HEAT), air compressor(max 20 to 40psi) or a good seat of lungs.
Jul 10, 2008 | Kenwood KD-291RC Turntable
113 people viewed this question
 Grubhead
Grubhead
