Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
I GOT SOAPY WATER ON OTHER SIDE OF GLASS. TOOK 6 SCREWS OFF. INNER STUFF MOVED. CAN'T REMOVE PANEL. FEEL REAL STUPID. CAN I LIFT PANEL, CLEAN GLASS.
I TRIED TO LIFT DOOR AT FIRST BUT DIDN'T MOVE VERY MUCH AND DIDN'T WANT TO FORCE.
  • handy_not Feb 23, 2008
    Thank you! I removed the door (needed help--because I removed the wrong screws that attached the hinges, so it was cumbersome). Then took the door apart, removed the glass sections and cleaned the glass. From this day forth I will be diligent when cleaning the inside glass and not get the soapy water too close to the edges. Thank you, again!
  • Anonymous Nov 23, 2008
    Right side of door handle came off and now I am trying to remove the panel and re-attach the screw that came loose. I can't seem to remove the panel. I've removed all the screws on the inside of the door and the panel still wont come off. I'm sure there are other screws to remove.
    Thanks
  • 770 Answers
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Posted on Feb 22, 2008
  • Gary Davd
    Gary Davd Feb 23, 2008
    Your Welcome.. Glad I could Help
How to I take inner glass off the door to clean
you will have to remove door, then remove all necessary screws on door framing which sandwiches glass between inner and outer panels. How to Take Apart an Oven Door to Clean the Glass
Jan 06, 2016 | Ovens
HOW CAN I CLEAN BEHIND CONTROL PANEL TO REMOVE FATTY DEPOSITS ON THE BACK OF THE GLASS
The deposits can be a bit of a challenge as they re on the inner door glass and may be cooked on the glass. You must remove the door off the hinges first and then remove the inner door panel. It will be attached by screws. Once the inner panel is removed, you can remove the glass and clean it with a product called Goo Gone.
Oct 25, 2015 | Ovens
How do you clean the dirt/food "in between" the glass in the bottom oven door
Open the oven door. In the inside you will see a number of screws along the edge of the door. Unscrew them and you will find that you can lift/split the inner panel from the outer panel. If it sticks look for more screws at the side of the door to make sure that all the screws are removed. Lift the inner panel carefully an you will have access to the "inside" of the glass panel. Re assemble by reversing the procedure.
Mar 31, 2015 | Ovens
Replace inner glass on kitchen aid wall oven
This can be quite a difficult issue to deal with.. This is really a job for a pro technician, honestly. But if you should choose to try it. Remove the oven door from machine, by opening door slightly and looking at hinges you should be able to be able to slide a small arm on the hinge that locks the hinge and stops the door from closing. You then hold door and move toward closing it and lever the hinges out of their space and carefully place door on floor. Then you have to disassemble the door and remove glass. The video below IS NOT EXACT but will help you with what your up against.
Feb 02, 2015 | Ovens
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Smeg 90cm oven - removing inner glass plate of door
First you have to unmount the door from your oven (descriped in the manual how to do).
Then next, remove the screws that you have mentioned already of the inside of the door (the inner glass plate is mounted by adhesive on the outer part of the door). After yo have removed the screws, the inner door can be parted from the outer door. Wupti - now you are able to clean the inner side of the glass platen of the oven door.
Per Oding, Denmark
Jan 06, 2009 | Ovens
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
1,192 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
