Question about Sharp Viewcam VL-AH130U Camcorder
Will not play tapes just a very fuzzy screen, will record on camera but not playback used cleaner for heads still no good
It may be the speaker from wet water if the sound may be lost then the camera may not work
Posted on Aug 01, 2012
  • Sharp Master
  • 12,061 Answers
Sounds as though the "Playback" heads have gone faulty.
Posted on Feb 08, 2010
After recording and replaying, the picture is "sliced up". I've tried cleaning head with dry tape, seemed to help but still there. Trouble is it seems to vary each time I play the same tape.
Do not use a head cleaner - they can damage the heads. Insert a brand new high quality tape and perform a record. Let it record through the entire tape. Then, play back an original prerecorded tape and check playback.
Nov 15, 2010 | Canon GL1 Mini DV Digital Camcorder
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Canon Gl2
Sep 18, 2007 | Canon GL2 Mini DV Digital Camcorder
Cannot playback hi8 ccd trv107e pal
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Try to playback the tape and the screen is all blue
your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Jan 24, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Lines in tape playback
Someone here recommended taping with the lense cap on in a quiet room for 5-10 minutes. When I played it back, no more skipping or gray lines. This worked for me!!!!
Jul 02, 2006 | Canon ZR85 Mini DV Digital Camcorder
Sharp Viewcam VL-AH130U Camcorder Logo
178 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
