Question about Bosch WFL 2463 Front Load Washer
Belt seems to tight cant attach drom to moter
  • Bosch Master
  • 3,463 Answers
To check to see if the drum is free, spin the drum by hand, there should be no resistane at all.
If there is, then it could be the drum bearings are siezed, or there could be something stuck between the inner and outer drum.
If drum is free, then try again, they are tight to fit, I assume you have right size belt?
Posted on Feb 08, 2010
Eastest wat to put belt back on moter and drum
Hook the belt on the motor pully first and then on to the drum and then turn the drum at the same time to run the belt on. The belt will never go on if the motor adjustment is not correct. If this has not been touched it should be OK. If the the belt is at the right tightness it should "ping" if you flick it with your fingers.
Sep 30, 2014 | Washing Machines
My treadmill lights up but when i push start it dose not go on
please adjust the REED SWITCh, see the diagram attached, clean it, and tight the wires connector.
2) tight the ribbon cables for keypads switch, tight the wires connector from display board vs lower board.
3) try to LUBE the deck belt accordig with the instr. manaul
4) lube the rollers bearing.
5) test the motor voltage input, if there are the motor NEED repair.
6) measure the output voltage board, for input voltage board, if there are NOT, the board is faulty. see the diagram attached.
God bless you
Jul 30, 2012 | Exercise & Fitness
My drum on my dryer is not yurning but all else seems to be working fine i have given the drum a push it then turns but when it stipos it will not move again
the belt could be bad or the moter if its the moter u will probably hear humming but the only way to really find out is to take the dryer apart to get to the moter and look at the belt
Jan 24, 2012 | Tricity Bendix TM220W Electric Dryer
My belt on a 1989 suburban is scretching. how do i tighten it?
The drive belt has an automatic tensioner pulley. It will be a pulley on it's own attached to an arm. It'll be the top left pulley under the drive belt if there are only 2 at the top, or it'll be on the top righton top of the drive belt if there are 3 or 4 pulleys across the top.
Check to make sure it is moving freely. You can do this by attaching a wrench to it and moving it down if it is under the belt, or up if it is ontop of the belt. It should require a bit of force. If it doesn't move or is easy to move then it needs to be replaced. If it feels like it's moving freely and the spring seems strong then your belt is stretched past it's limit and needs to be replaced.
Alternatively it may be screeching due to a pulley seizing up. Check to make sure things like the idler pulleys or the A/C and Alternator pulleys move freely.
Jan 06, 2011 | 1989 Chevrolet Suburban
How do I tighten my alternator belt? I just put in a new alternator, but i cant pull the belt tight enough in tightening down the swivel screw securing the alternator.
did you get the right length belt or correct belt? there should be a bolt to loosen or tighten your belt separate from the alternator.attach bolts..
Feb 26, 2010 | 1987 Subaru Gl 4WD
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
Tighting the belt
yes there is and its quite simple.num1take a good look and find the two pullys that are most apart pull the moter out towards the front of the machine ,before you tighten make sure the tention is no more than 14 ml.tighten .problem solved.adrian
Feb 17, 2009 | Washing Machines
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
Blower motor location for 2000 Caravan
The motor is located just under the glove box on the passenger side. I remove the glove box then the panel below the glove box. I also go ahead and pull back the carpet and the padding under the motor. It is held in place by 3-4 bolts that take a 7-8 millimeter socket. I use a swivel extension for the back bolts. The motor with the fan blade attached is a tight fit, just keep wiggling and pulling it should come out. Try to remove the old moter without cracking the fan blade, because sometimes the replacement motor doesn't come with a blade
Sep 17, 2008 | 2000 Dodge Caravan
Bosch WFL 2463 Front Load Washer Logo
55 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
