Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a International tractor 1969 model 276 gas. When I run it the gas is going in the bas with the oil. Any idea what might be wrong
2 Suggested Answers
  • 51587 Answers
SOURCE: Have a 1969 propane john deere tractor. Can't get to run. any suggestions?
YES perhaps a dealer
Posted on Aug 22, 2015
4020 steering to the right is lazy , steering to the left is good , hydraulic system holds 2000 lbs. good any idea of problem and how to fix. gear shift is under steering wheel pretty sure a 69 model.
Have you had this tractor for some time or is it a recent acquisition? The JD 4020 1969 serial numbers go from 201100-222159. Lazy power steering to one side has two commom possibilities, internal leakage in the control valve, Or, if the front end had been worked on, the tie-rods were not set to center the steering wheel when setting the toe-in. If that is the case, and the steering wheel is properly centered when driving straight or has fewer turns turning right than when turning left, the steering wheel was re-centered by removing it and resetting it on the steering shaft spline, in which case it is rarely perfectly centered. If that is the case, the control valve may not open much and restricts oil flow when turning right.
It is possible the steering cylinder piston seal leaks in one direction more than the other, or that the front wheel toe-in is wrong.
Sep 04, 2017 | Cars & Trucks
The duration and lift for 1971 Lincoln 460 CI engine camshaft
COMP CamsĀ® - Ford Engine Technical Specs and Information
www.compcams.com/Pages/411/ford-technical-info.aspxBig Block, 426 Hemi, 1966-1971 .... With the V8 engine sizes ranging from 221-460, there is an engine size and configuration to cover just about any need or application. ...The 4.6L version of this engine first came out in the 1991 Lincoln Town Car ... All of the factory valve springs are designed to work with a certain lift cam, ...
1969 460 Cam Profile? Please Help - Ford Truck Enthusiasts Forums
www.ford-trucks.com/.../284830-1969-460-cam-profile-please-help.htm...
Sep 18, 2004 - I have searched enough to know that a 1969 460 from a Lincoln had 365 hp and about ... to look at the stock engine blueprints they have but they do not list a 460 until 1971. ... lobe lift .253/.253, valve lift, .443/.443 dur 276/276 ..... Diesel Engine Fuels, Competition, Performance, Engines & Troubleshooting ...
Oct 03, 2015 | Lincoln Cars & Trucks
Lawnmower looses power. Sounds like it is running on one cylinder. Have changed spark plugs, air filter, gas filter, drain gas, pulled fuel cylinoid from bottom of carbarator and drained. Replaced and...
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
Aug 05, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
I have a 1961 international 340 u tractor. i want to change the oil in the trans and the diff. i need to know what kind of oil and how much. the tractor is a basic 340 u no pto no hydro and it has the fast...
I should have taken an oil sample and let it determine by a oil analyze laboratory. Every hydraulic company can fix that for you. It doesn't cost much. If you mix the wrong type of oils, you will be sorry to spend not that little money. I don't know the quantity.
kind regards Marcel van ****
Feb 10, 2010 | Farmall Toys
I have a 1975 International 574 tractor. it starts fine but doesnt keep running. no reaction on the speed control lever or the pedal! Lever on engine does move! runs for a couple seconds and shots off...
i have a 574 deisel international tractor! bush hogged yesterday, ran fine, park it, started it up the morning on first lick, but when to take off and it would not thottle up any at all! changed fuel filters, and it just will idle, any clue anyone?
Dec 30, 2009 | The Times Case Corporation Tractors...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
232 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
