Question about Foxconn 845GV4MR-ES Motherboard
My motherboard won't boot up. the fans don't come on, hard drive spins up. no vga output to monitor. cpu is getting power. does anyone have the mobo jumper settings?
  • wackywoofa Feb 08, 2010
    I swapped cpu's, and power supply. I know I'm getting good voltage. Just seems weird that the cpu fan won't spin up. Checked fans on another HP and all is well. My other question concerns what are jp5 jp6 used for on the mobo? And what are the correct settings for them? Thanks in advance. By the way I'm not a newbie to this. I've been working with computers since 1976. Thanks again.
  • 4,889 Answers
Checking your motherboard specifications, I see that it has an onboard graphics card. I couldn't understand what jumper settings do you need. You mean you want to restore the CMOS settings to factory defaults? Did you disable the motherboard's onboard graphics to install a different graphics card?
Please answer these questions so that I can help you with your problem.
Sai.
Posted on Feb 09, 2010
  • Foxconn Master
  • 19,396 Answers
Hi.
If the motherboard does not start at all, usually it is not just a matter of jumpers.
Here the motherboard manual and other resources for the model posted in title.
If that does not work, try starting the motherboard with a minimal set of devices. One memory stick, PSU, CPU and Heathsink, and only the on off switch. Connect the Video adapter if you need to use a PCI or AGP adapter instead of the integrated chipset. Ensure also that both the PSU connectors are well plugged, and that the heathsink fan is plugged.
Ensure that all screws holding the motherboard to chassis are in place. They allow grounding. If they are not well in place, some motherboard may no start (most will even start with no screw, but that is not a good way to proceed).
If still no luck, then either motherboard or CPU is faulty.
Regards.
Posted on Feb 08, 2010
Won't boot... power and/or battery issues
Check your ram, then your power supply. an intermittent fault such as that would be difficult for anyone to solve as there are no details of the symptoms. Do you get to POST? Do you get the welcome splash screen? What operating System are you running? Do you get a blue screen when it crashes? How old is the Power supply? Does the CPU fan run?
Apr 04, 2013 | ASUS P8Z77-M PRO- LGA1155 Intel Z77...
I have change my old CPU intel Celeron D 3.06Ghz to intel dual 2 core but my pc no display my pc is power on my monitor is power on also. The CPU fan is running slower then old CPU . My motherboard
is the monitor running through a vga connection? sounds to me like the mobo is bypassing the connection your using and sending your video signal elswhere. did you change any settings in the bios? try other video outputs to get the screen on then go into bios settings and change the video output to a connection your familiar with. help is here if you need it :)
Nov 20, 2012 | Computers & Internet
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
Want boot up. Whern you push the power on button, one light on the CPU comes on and all fans come on. There is one beep when you push the button. The CD drive has power. The moniter does not come up. I...
it means machine working fine but display problem check it your RAM check with a soft cloth may monitor is also avilable or check behind the VGA cable proper connect it or not
Sep 23, 2011 | ASUS P4P800-VM Motherboard
HP media center pc ,1170n will not boot. black screen. You can hear the fan come on but black screen.
Sounds like a capacitor has blown on the motherboard, but before condemning it, check the following:
1.) Does the CPU fan turn and does the heatsink get warm after a few minutes?
(This indicates that power is at least getting to the CPU
2.) Check connections of ALL the main power connectors (ie: the 20/24 pin plug to the mainboard and the smaller 4 pin plug to the mainboard.
(If not firmly inserted will stop the board from firing up)
3.) Check the graphics card is firmly seated and test with anew graphics card to eliminate the issue being with the graphics card / check tightness of the VGA cable to monitor and card
4.) Remove all but the main power and 4 pin power plugs and try rebooting to eliminate hard drive or DVD drive failure
5.) Remove and replace each ram module in turn try booting in between
6.) If you have a spare PSU, replace the existing one and test the board using that, sometimes the PSU appears to work, but lacks power to fire up the board.
After all that, you are down to the mobo or CPU, you can try a new CPU, but I feel that the issue is with a blown capacitor or a burned circuit trace, only close inspection of the mobo will reveal bulging, leaking or blown capacitiors (small cylinder like things on the motherboard)
Jan 17, 2011 | Computers & Internet
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
Mobo will not power on if two sata drives are connected . The fans on system and cpu will not spin. System will power on and fans will spin if second hard drive is unplugged and system will post and boot...
good day sir, hi, its either your motherboard does not support 2 sata drives simultaneously or your motherboard sata port is bugged.
Choices:
1. get a bigger hard drive
2. use a PCI to SATA card for your extra SATA hard drive.
3. replace your motherboard.
Hope this may help.
Dec 17, 2009 | ASUS Computers & Internet
Motherboard will not display video!
remove everything except for video card and memory cd hard drive etc give it a try
if it shows boot screen you have problems in something you disconnected retry one at a time
if not try different video card
Aug 16, 2008 | ASUS M2N-MX Motherboard
Foxconn 845GV4MR-ES Motherboard Logo
99 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
