Question about Lexmark Z1420 Printer
Won't Print When I turn it on the green light just blinks, the printer cartridges slam from one side to the other and the wi-fi light is not coming on.
  • Rajeeves Feb 23, 2008
    The wifi light would not turn on at all
    Genius:
  • 3,587 Answers
No worries..start by getting new driver for that here
Posted on Feb 28, 2008
I have a cannon WiFi printer, the colors have emptied quickly. I don't use it that often.
If its the original cartridges, they dont come with much ink. look them up on Ebay to order.
Oct 19, 2015 | Cannon Office Equipment & Supplies
My Canon Pixma MP990 stopped working. First the wi-fi light went out, and the LCD screen went dead. Then the blue light stopped coming on at all, and all I have when I plug in the printer is the yellow...
It sounds like you have an electronic problem, it is most likely a faulty scanner or logic board. although a faulty print head can take out a logic.check that there is no burning smell or damage evident on the underside of the print head before trying a logic.
the machine will require disassembly and parts replacement.
Aug 16, 2011 | Canon Pixma MP990 InkJet Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
HP DeskJet 812C Hardware Problem! with Printer cartridge carriage. Printer Cartridge retracted into right side of case will not come out. There is No paper jam in machine to prevent it from doing so. ...
Disconnect the "data" cable (parallel or USB).
Disconnect the "power" cable.
Reconnect the "power" cable.
Turn the printer on.
Lift the printer's lid -- the print-carriage should slide the printer-heads to the "middle" position.
If all else fails, take the printer to a qualified technician, for more trouble-shooting.
Feb 02, 2010 | HP DeskJet 812c InkJet Printer
Printer won't print. Green light blinks once, then turns amber & blinks 5 to 6 times, then turns green once again. I have replaced all new ink cartridges
5 times says the printhead is bad and needs to be replaced.The part number is stamped on the side so you can get the right one.
Oct 30, 2009 | Canon BubbleJet i560 InkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Blinking lights
This exact thing just happened to me. I tried EVERYTHING in the way of troubleshooting - turned printer off/on, plugged/unplugged, opened/closed top, pressed all the buttons on the front right - FINALLY, I took out and put back in both ink cartridges and the light finally went to just green, as it should be AND it printed! Hope this helps!
Jul 31, 2008 | HP DeskJet 5550 InkJet Printer
Tries to print, but then ink cartridge moves to left and it all stops
the printer gears assembly is brokem or gor cracked so it is giving this message that ---cannot complrte print task--- just get that assembly replaced to make it proper. it will cost u near $20 for the assembly.
Mar 18, 2008 | Lexmark Color JetPrinter Z23 InkJet
Lexmark Z1420 Printer Logo
237 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
