Question about Acer Altos G510 Server
No problem as such - can you tell me whether G510 has USB port to take USB tape back up device ?
  • 596 Answers
Yes, the G510 has two (2) 1.1 USB ports and should function well with a USB tape back up device.
Good Luck
C2Solutions
Posted on Feb 10, 2010
Where do I plug in the usb printer cord to a compaq presario
You can generally use any USB port to support a USB device. There are minor details such as speed but the computer will generally tell you if you plug a device into a slow (USB 1.1) port when the device will work better with a USB 2.0 or 3.0 port.
The newer your computer, the more likely it is that you will have all faster ports.
Sep 14, 2012 | Compaq Presario 5000 PC Desktop
The usb ports will not work.
Chk whether the USB ports are disabled in the device manager by Right clicking on My Computer and then Manage and then Device Manager
If not disabled in device manager then chk through BIOS. (USB - Enabled or Disabled)
If not disabled then chk for any viruses in ur computer.
Tell me if not solved..
Jan 31, 2011 | Sylvania G-Netbook
None of my usb ports function as "high-speed" 2.0 , and I constantly get the message that my device can perform faster if I connect it to a high speed USB 2.0 port. I bought this computer brand...
you usb ports are to slow for the usb 3.0 device that message keeps coming up saying that the device is better then your usb ports you have on your computer...almost every computer now have 3.0 usb ports that have very fast transfer rates for data back and forth. well i tell you the message you get is not trouble with your usb port it just trying to tell you the transfer rate will be slower with your usb 2.0 port... i hope this helps you.
Jun 13, 2017 | Sony VAIO Digital Studio PCV-RZ22G PC...
Chick and wheel works but mouse won't move pointer
  1. Try to connect the Mouse receiver to a different USB port. Then, check the behavior of the device.
    Also, try to connect the receiver to a USB port on the back of the computer. The ports that are located on the back of the computer typically have more power available. Note Bypass any port replicators, USB hubs, KVM switches, and so on. Connect the receiver directly to the port.
  2. Replace the batteries, and determine whether this resolves the issue. Make sure that you have inserted both the required batteries into the wireless pointing device and that they are positioned in the correct direction. After replacing the batteries, press the reset, or resync button on the mouse or on the receiver.
  3. If the issue continues to occur, test the mouse on a different computer in a different environment. If you can replicate the problem in a different environment, you may have a defective device.
  4. If the mouse buttons are recognized, and the pointer won't move, you may have a defective device. However, the best way to determine whether the device is defective or damaged is to try the device on a different computer.
Jul 12, 2010 | Logitech V550 Nano Mouse
Cant connect through USB modem
First you check the USB port with another USB device like pen drive etc or use anothe USB port with your same device. Similarly you check the USB device with another computer to verify whether there is problem in the device.
Jun 17, 2010 | Computers & Internet
My U.S.B port are not working
Pl check from device manager whether the USB ports are enabled or not. If disabled, pl do enable them.
May 23, 2010 | Acer Aspire 5100 Notebook
The external HD function only in the back USB port
Pl check for the serviceability and also whether the front ports are enabled or not from the device manager option using right click manage option on My Computer icon on desktop.If these are disabled , please enable them.
May 23, 2010 | Verbatim SmartDisk Firelite Portable USB...
I have an ACER TravelMate 2355LCi Laptop. It has 2 USB Ports in the rear and 1 USB Port on the left hand side (if you are facing screen). None of them work. Are thre any drivers that can be downloaded for...
Hi!
What you could do is first check in the device manager. Go to control panel and click on system. From there on the top click on hardware. Then click on device manager. Look for any icons that would have an X, ?, or ! on it. If they do right click then click update.
If that still does not work go this page
http://tinyurl.com/acertravelmate2355drivers
and download all the drivers including the chipset and reinstall them.
I hope this helps.
Jubert
May 18, 2010 | Acer TravelMate 2300 Notebook
USB port is not working
first check whether ur os is windows 98 or xp if it is 98 then for any device u need usb driver. if it is xp ten its ok. check the device manager whether usb driver is loaded in ur system. right click on my computer icon not the shortcut icon. then select mange then select the device manager from the option available on left hand side of the window. then check the usb section whether any driover is loaded into ur system. if not then install from ur motherboard cd. if that also does not work them u need a replace of the usb port.
tell me u have a error message window cannot recognise the usb. if this appears then it need a replacement of the port. thank u
Feb 25, 2010 | ASUS P5PE-VM Motherboard
The usb ports will not work,therefore the mouse nor the keyboard will work
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
Nov 05, 2009 | Dell 2 Button Mouse 6u226
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
See all Acer Altos G510 Server Questions
Acer Altos G510 Server Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
