Question about Philips 170B7CS (Silver) 17 inch LCD Monitor
Attention "Check Cable Connection"
It sais Attention "Check cable connection" no matter how many times i retry the cable. Also none of the buttons work when I press them excepth the power.
2 Suggested Answers
JUGGALOTUS
  • 151 Answers
SOURCE: my monitor says
are you sure you dident set the video card to a resolution that the monitor does not support? try a diffrent monitor if possible
Posted on Oct 19, 2009
Starcom modem sip has noise on the line
Line noise comes from several conditions such as a bad cable connection, a bad in/out port, a bad power transformer, communication line failure, etc. Check all conditions and if none of the suggested are defective, the modem has a defect and needs attention.
Jan 20, 2014 | 2wire StarComm 1442E-003-2 Stand alone,...
HDD model name: None
From the description the problem is in the hard drive, have the hardware tested to be sure.
Jun 27, 2012 | Acer Aspire 4730-4516 Notebook
Have a black line across the screen on my Toshiba 32AV502R LCD TV, no matter what input I'm using. It started as a bunch of visual "noise" and after turning it off and on several times,...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken
Good luck in solving the problem.
Jun 09, 2011 | Toshiba 32AV502R LCD TV
I have a green tinted display, with some horizontal lines crossing the screen. Is this 2003 model 51G500A projection set worth repairing, or would it be advisable to purchase another set? Is it a matter...
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them. Good luck.
May 17, 2011 | Hitachi Televison & Video
My nokia n73 was accidentally disconnected while i was reinstalling its software. Now my phone is switched off for ever. It is not working. Can this be fixed? How? Is this expensive or a simple matter?
Download the latest software updater and pc suite from Nokia.
Plug in your phone and cable as if you were doing the update still.
The updater should indicate searching for device it should find the device and ask if to (re)install the update.
Click yes.
On numerous occasions it will tell you retry.......just keep clicking retry if you are instructed to disconnect cable do so connect again and click retry...keep doing this each time.
Eventually your phone should boot up again.
May 03, 2011 | Nokia N73 Music Edition Smartphone
Hi! I want to remove the OSD attention from my monitor. How do I manage this? It's necessary to me remove this attention pop out.
OSD popup no signal If you are getting a message that says something like"Check cables" "no signal detected" or something like that,it is likely that your monitor is operating correctly. I would suggestchecking your cables, make sure that the computer is turned on, and if thatdoesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I amthinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables aretypically blue.tgvern_4.jpg
Another common connection that is used is a digital HDMI (left) or DVI(right) connection. DVI cables often have white endconnectors. How your PC connects to your monitor will determine thesource mode you want to use on your monitor. (Obviously this is the cableview but the connection on the monitor itself will look similar.) tgvern_5.jpg
If none of these tips helps, I would suggest hooking the same monitor up to adifferent PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on yourmonitor. If it works on another PC, then your computer may have a videoproblem.
Otherwise, if it still does not work your monitor have a problem displaying viathat connection. If possible I would suggest switching to a differenttype of cable and re-try the above steps.
Mar 20, 2011 | AOC FOVI F19S Monitor
When watching television my tv switches from mono to sap mode on it's own, which interrupts the sound, it occurs most during commercials for some reason. I've tried pressing the mts button to put it on sap...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 03, 2010 | Akai LCT2701AD Television
We have comcast for cable connection. when the
1. Reboot the computer that is connected "wireless.
2. Go to the DOS command prompt type "cmd" to get to this.
2. Next do a ipconfig /all this will tell if you have media connect. If not then do ipconfig /release >> then ipconfig /renew.
this is all done at the DOS prompt.
Apr 24, 2010 | Linksys Wireless-G WRT54G Router
Philips 170B7CS (Silver) 17 inch LCD Monitor Logo
863 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
