Question about Sony KV-27S42 27" TV
Won't turn on - comes on and goes right back off
It's blinking four times and then pauses. I know it's telling me something, but what? Is it worth getting repaired? It's a heavy TV!
  • LSP123 Feb 23, 2008
    No, the picture was fine. Worked one day, didn't the next. I can hear it click on and then it clicks right back off.
  • Sarge095 Jun 08, 2008
    Exact problem, except the stand by light flashes 2 times then long pause.
Is the picture good or is it dull and dark?
A dull aka weak picture tube will cause low beam current and blank the screen. Last set I had do this I turned up the screen control to make it brighter. Use caution and don't turn it up too high were you see vertical retrace lines in the picture.
Posted on Feb 22, 2008
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Won't turn on
If power light comes on for a few seconds and goes off: on front of set press and hold both the Menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Please let me know what error code you find and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65511 65" Rear Projection...
When i turn it on it stays on for about 2 seconds and turns right back off
Model indicated is 2002 model. It should have the self check feature:
When you turn on and green light goes off: On the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and then release both buttons.
The power light should blink a error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know (comment here) what error code you see and I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 09, 2010 | Mitsubishi VS-50111 50" Rear Projection...
TV won"t stay on turns off in 3 seconds WS 55807
Do the self check when power light goes off.
On front of set press and hold both the menu and input buttons for 5 seconds or longer and release both buttons.
Power light will blink a error code like: 2 blinks, 2 blinks, a pause and repeat about 4 more times.
Let me know what error code you find and I will tell you what it means.
If this information told you something rate this solution as very helpful as I do this here for free.
SD TECH
Aug 28, 2010 | Mitsubishi WS-55807 TV
What is the going price for a power supply on this brand T.V. and how can I be sure its the power supply?
If the power light comes on when you attempt to turn the set on and the goes off, do this:
On the front of the set press and hold both the Menu and Input buttons for at least 5 seconds and then release both.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code and I will tell you what it means.
SD TECH
Aug 24, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi rear projection tv.. 55 inch made in june 2003... will not turn on... no lights blink nothing no sound.. push button nothing happens.... looked in back not knowing what to look for or look at...
IF power light on front comes on for a second or two and goes off do the self check this set has:
On front of set when power light goes off, press and hold both the Input and Menu buttons at the same time for more than 5 seconds and release both buttons.
Power light should blink a two digit error code like: 2 blinks, 2 blinks, a pause and repeat the code four more times.
If this information helps and you want to know what error code found means rate this solution as very helpful and comment here and I will tell you what it means.
SD TECH
Aug 22, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Keeps turning off
IF power light comes on and then goes off in a few seconds Please do this:
On front of set press and hold both the menu and input buttons at same time for at least 5 seconds and release both.
Power light will blink a two digit error code like: 2, blinks, 2 blinks, a pause and repeat the error code four more times.
Let me know error code and I will assist you.
SD TECH
Aug 20, 2010 | Mitsubishi WS-55809 55" Rear Projection...
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
No picture. on light blinks four times pauses and blinks four times.
can any 1 tell me how i can fix this problom igot this kp-53S75 4free it blinks 4 times and nothing but inotthis a small scair panale on back lower right corner isthis plase to plug in a scanner to read its problems
Oct 19, 2009 | Sony KP-53S75 53" Rear Projection...
Sony KV-27S42 27" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
