Question about HP Deskjet F2210 InkJet Printer
I am printing on an hp f2210. I am printing from Microsoft word. It is printing but VERY slow. It will print one line then pause for approximately 3 minutes and print the next line. I have tried printing from my desktop and laptop and am still getting the same problem. I have unistalled the printer drivers and reinstalled. I have unplugged the printer. Nothing seems to help.
SOURCE: HP PSC 2210xi all-in-one won't print....Please HELP!
I had a problem downloading HP psc 2210 software from the internet after a reinstall of winxp. One of the device drivers was not completing its installation. HP support provide a troubleshoot process to fix the problem. This process is manual but did complete the installation of the device driver. The printer is working.
Posted on Feb 16, 2008
  • 160 Answers
SOURCE: problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Posted on Jan 06, 2009
SOURCE: HP psc 1315v (printer, scanner, copier) Will not print
The test page printing out every time it gets turned on is the printer's way of telling you it wants to be calibrated. Lay the test page on the scanner (follow the pictures on the test page) and scan it in. This should fix that problem and the "occasionally after waiting, something prints" problem.
Unfortunately, I don't have an answer to the "E" on the display or check printer cartridge light. Hope this helps!
Posted on Jan 23, 2009
shadiabed
  • 72 Answers
SOURCE: HP LJ printer printing slowly
try to change the driver on the network definition
Posted on Jan 05, 2010
HP Xpert
  • 112 Answers
SOURCE: HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Posted on Jan 19, 2010
Prints have streaks -F2210. printer not indicating ink finished. Have tried cleaning.
1. Power down the printer.
2. Pull the ink cartridges out and clean them with a paper towel/napkin and some isopropal or rubbing alcohol.
3. Replace the cartridges.
4. Power the printer up and run the head cleaning cycle again.
Test your prints. If they are still bad, you may have a bad formatter board. This would mean it is time to replace the printer.
Aug 29, 2011 | HP Deskjet F2210 InkJet Printer
My Printer ( HP Deskjet F2210 ) will not print. It is installed, plugged in, and has ink AND paper. I've waited several hours for it to print but it will not work. It's stuck in the queque, or...
Go to START then RUN and type services.msc and click on OK. This should open services window. Scroll down to on the list and look for Print Spooler. Click on STOP on the left pane then restart the service. This should clear put the stuck document in your print spooler and you should be able to print again.
Hope this helps.
Jun 14, 2011 | HP Deskjet F2210 InkJet Printer
It will not print Word documents. it pulls a blank piece of paper through. It will print in notepad
there is something wrong with your Word printer setup. Go to Word, then from the File menu select the Print option and when the print window opens see if the HP deskjet is selected as default printer. Then, in the upper right quadrant theres a button called Advanced Settings, or Prefferences (depending on your Word version). Click that button and check to see if the HP printer is set as On Line, and is set to print odd and even pages. Also, check the margins of the paper. Ink Jet printers cant print over the full page, there's always a need of some margin on each side of the paper, so you'll need to set the margins from all sides on at least 0.5 inches
Jan 18, 2011 | HP Deskjet F2210 InkJet Printer
Page printing is very very slow . cartage is moving v v slow
You may need to increase your Print Spooler size, or you may not have much HDD space..You need at least a few GB free to print.
Jul 14, 2010 | HP Deskjet F2210 InkJet Printer
I want the software for printing and scanning software for hp diskjet F2235
Hi
I recognize the importance of resolving this issue and I look forward in providing you with the necessary assistance you need.
Problem : Need the Software for HP Deskjet F2210 All-in-One Printer
Operating system : Not mentioned
Solution
Click on the link below to get software compatible drivers with
Following Operating systems
» Microsoft Windows 7 (32-bit)
» Microsoft Windows 7 (64-bit)
» Microsoft Windows Vista
» Microsoft Windows Vista (64-bit)
» Microsoft Windows XP
» Microsoft Windows XP x64
» Microsoft Windows 2000
» Mac OS X
» Linux
Click on the Following Link
Click on the OS and Download the Drivers
As you work through the article, please note the result of each step, including any error messages you receive. If you require further assistance, please update your case with these details. The more specific the details you provide, the better our ability to resolve the issue quickly.
Cheers
Tejodhar Atreya
tejodhar.atreya@gmail.com
Jan 04, 2010 | HP Deskjet F2210 InkJet Printer
Slow Printing
You need to change the pickup roller. The rubber dries out and it is not able to pick up the paper quickly. I had this problem with our printer at work. We changed the rollers and its printing like new again.
Apr 24, 2009 | HP LaserJet P3005n Printer
Can not print anything off the internet
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 12, 2009 | HP Deskjet F2210 InkJet Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
Oct 18, 2008 | HP LaserJet 2430dtn Printer
Slow Printing
it may just be a slow printer head, maybe an upgrade is in order. look on the box for page printing speed.
it may also be that you have the resolution set too high for basic printing. try turning this down slightly.
hope this helps.
kev
Oct 03, 2008 | HP PSC 1350v All-In-One InkJet Printer
HP Deskjet F2210 InkJet Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
