Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My 3/4 hp A. O. Smith pool pump motor stopped running so I took the end cap off and notice a plastic part that connects the powers source was melted. Is the motor shot or can it be rebuilt?
  • 12,061 Answers
All motors can usually be rebuilt, unless physically damaged you have a good shot at rebuilding.
Posted on Feb 08, 2010
AO Smith 1.5 HP pool pump motor. Voltage selector broken. Three wires to the switch,Purple, black and white w black stripe. Which two should be connected for 230 volt operation?
Try the black to L2 (L2 will be your Purple). L1 should be connected direct and separate. The black/white striped wire should get capped off.
http://www.inyopools.com/HowToPage/how-to-use-a-multimeter-to-test-a-pool-pump-motor.aspx?CommentPage=1
Jun 17, 2017 | AO Smith Pool & Spa
I am looking for a parts diagram for an A.O. Smith pool pump motor SP3220Z1BE.
The motor is made by A.O. Smith in Tippton, OH. You can try calling them, and with any luck you may get a kind soul that can get you a splsh sheild. It is probably not a part you can purchase from a distributor, but that is an option you can also pursue. Good luck.
Mar 05, 2013 | Hayward 2HP Pool Pump Motor A O Smith...
I have a 1.5 HP AO SMith pool pump motor that just stopped working. It's only 3 years old. It would hum but not start. I could get it to work by rotating the end shaft. I took the motor apart looking for a...
IT HELPS IF YOU HAVE THE RIGHT PICTURE OF YOUR MOTOR OR MORE INFO.. BUT GOING FROM THE PICTURE THERE IS A CAP UNDER THE LITTLE BUMP ON TOP OF THE MOTOR, IT'S CALLED A RUN CAP AND WILL STOP THE MOTOR FROM STARTING.. SEARCH YOUR LOCAL AREA MOTOR FREE POOL PUMP MOTOR TESTING.
ITS TIME FOR A NEW SHAFT SEAL, SO YA CAN KILL 2 BIRDS WITH ONE STONE ... HAVE THE SHOP REPLACE THE SHAFT SEAL! AND ASK THEM HOW YOU CAN TAKE BETTER CARE OF YOUR PUMP? ....... REMEMBER TO ALWAYS PRIME THE PUMP AFTER A REPAIR !... THUMBS UP PLEASE ...JAY
Aug 12, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
My A O Smith 1 1/2 hp pool pump motor hums when it is turned on. I pulled the pump apart to check it and found no problem. I cut the motor back on and gave the impeller a turn and the motor took off...
the motor pictured has no start cap it has only a run capacitor and shold be a 25 or a 30 uf run capacitor around 10 - 20 $ and will work most of the time on this style motor.. hey now if'n i was of any help leve feedback by hit'n the thumbs .. thank you jay your pool pump repair guy in longwood FLORIDA .
Jun 21, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
How to remove the end cap on a motor
Most models have two screws on the back then you just pull it off. Some will have a small cap you just pry off about the size of a half dollar.
Jan 31, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Hayward Self-Priming Pump with AO Smith 1 HP 56J frame motor. Stopped moving inground pool water. Added water to pump basket (low). Turned on pump, return jets sent "bubbles" into pool, stopped, then...
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Nov 20, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
55 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
