Question about Motorola Mobility RAZR V3
Help texting problem
My phone freezes when i use t9 texting and if i use one letter at a time entry mode it only lets maybe one word before phone freezes again i have to take battery out to get my phone to turn back on whats the problem
    Brigadier General:
  • 7,752 Answers
You need to have the mobile firmware reflash , take the phone to a mobile service center close to you and have it done.
Posted on Feb 22, 2008
How to undo predictive text v3
Welcome to Fixya. If you want to undo the preddictive text just follow the guide below.
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on Entry SetUp
3. Select the Primary Set Up or Secondary Setup by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
ITAP: it's a built-in software which predicts the word you are typing. THIS IS PREDICTIVE TEXT
TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter F press the number 3 button three times.
Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
To change from one mode to the next you can select it by pressing the top center button from a text entry screen, and Press on Entry Mode. Shortcut: you can press the # key on your phone when you are writing a message and you will see abc1 for your primary mode, 123 for numeric; @ for symbols; and abc2 for your secondary mode.
If you have questions please let me know. Thanks for using Fixya.
Apr 04, 2011 | Motorola Mobility RAZR V3
How to turn t9 off on a moto razr??
Selecting a Text Entry Mode
Multiple text entry modes make it easy for you to enter
names, numbers, and messages. The mode you select
remains active until you select another mode.
Press # in a text entry screen to select one of the
following entry modes:
Primary Your primary text entry mode .
Numeric Enter numbers only .
Symbol Enter symbols only .
Secondary Your secondary text entry mode .
Jul 13, 2010 | Motorola Mobility RAZR V3
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
Is it my imagination or is it true my new env3 does not support t9 or preemptive text?
From the front screen and keyboard:
(i.e. with the phone closed)
While entering a message, hit the main "OK" button for "Options".
Item #2 in this menu is "Entry Mode."
T9 is on this list.
Operating from the internal LCD screen and QWERTY keyboard:
Hit OK to get to main menu
Select "Messages"
Once in that menu, the left option key beneath the main LCD screen is "Settings" - hit that
On that menu, item #2 is "Entry Mode" where you can select T9
I have read of difficulties getting the enV3 T9 mode to add new "user" words that you might want to program into the T9 dictionary, so don't be surprised if you have trouble with that.
Oct 03, 2009 | LG enV3 VX9200 Cell Phone
Lg shine wont change to t9 texting mode
reset the phone settings then try again
Aug 01, 2009 | LG Shine (CU720) Cell Phone
Texting configuration gone wrong please help!
I have the same problem on my KP501, SOMEONE PLEASE ANSWERRR :( x
Jun 29, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    I'm having problems changing the texting mode to T9
    okay all you have to do is to go to messaging then hit reply or something then go to options then go to entry setup then go to primary setup and click on itap english and that t9
    May 11, 2009 | Motorola Mobility RAZR V3
    Cant set T9 as the default entry method on LG cu920
    yes you can set T9 as default on the Vu just go to the new message touch options and touch text entry mode and touch T9 Abc and that will become your default
    Dec 24, 2008 | LG Vu CU920 Cellular Phone
    Motorola Mobility RAZR V3 Logo
    52 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
