Question about HP Officejet 5610 All-In-One InkJet Printer
My Officejet 5600 printer prints perfect. However, sometimes it grabs the paper, then says paper Jam. and, it doesn't have a jam. Because of this problem, I can't align the printer. It prints the align paper perfect, then grabs the paper after it prints it. when I pull the paper out, it says paper jam. I push OK. it says cancelinng alignment
  • eqr5 Feb 08, 2010
    Thank you. Solution accepted
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the cartridges and visually inspect). Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
Where is the duplexer of the HP 4500 Officejet printer?
its located on the backside of the printer behind an access door. You can find a very good video from HP on clearing paper jams at YouTube. Here's the link:
https://youtu.be/lS1441RmrKY
Fixing Paper Jam HP Officejet 4500 Wireless All in One G510n
Jul 08, 2015 | HP Officejet 4500 Wireless All-in-One...
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
My HP5600 printer had a paper jam which I cleared. The printer still indicates a jam and I cannot get it to print.
try shutting it off and remove all cables connected with the printer. wait for a few minutes and connect all cables back and then switch on the printer. meanwhile, also shutdown your PC and turn it on again too. now try printing, it should work fine.
hope it helps.
Feb 18, 2011 | HP Officejet 5600 series
Paper Jam when it is not jammed. Can't print.
It could be an issue with the printer, make sure that there is no paper jam or check for any tiny bits of paper is side the printer, that could cause the issue.
However try reseting the printer
Follow the below steps to reset the printer;
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
This should fix the issue.
Sep 27, 2009 | HP Officejet 5510 All-In-One Thermal...
Paper jam
I have an HP 5510 All in one, and mine did the same thing. There was a plastic fingerlike thing that had hung up just to the right of the printhead, preventing it from moving. I removed the cartridge and managed to get the part unstuck with a screwdriver.
Oct 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Paper jam, cleaner kit
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
Jun 23, 2008 | Minolta magicolor 2300W Laser Printer
Paper Jam
Try putting a piece of tape or something sticky on the eraser end of a pencil and try to work out the paper. Sometimes, you can use needle nose pliers or other long nose pliers to grab the paper and pull it out.
Dec 13, 2007 | HP Officejet Pro L7680 All-In-One Printer
Multiple paper feed
The paper separator pad is worn out and will need to be replaced. It's a rubber pad that rests behind the paper pickup roller and is supposed to prevent what you're experiencing. Contact your nearest authorized HP repair center.
Apr 13, 2007 | HP OfficeJet K80 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
