Question about Navman iCN 520 GPS Receiver
As soon as you input route it starts to work without the car being driven
  • 377 Answers
  • Try to check maybe the gps is in a DEMO mode try to deactivate the demo mode.
Posted on Feb 09, 2010
2001 Camry 5 speed. It starts but it will not move. I can change gears without pushing in clutch. One mechanic said it was clutch and a different one said transmission is out. Which is it?
The clutch is not transferring power to the gearbox, which then is not turning, so that you can select gears without the clutch.Possibilities are
- clutch assembly has failed, possibly by the splined driven plate hub coming adrift
- clutch driven plate has become very worn and has lost contact
- slave cylinder has stuck through corrosion (assuming a hydraulic clutch) and is holding out the clutch independent of the pedal. This can be determined by watching it while someone depresses and raises the pedal.
I think it is unlikely the transmission input shaft has fractured.
Aug 14, 2015 | 2001 Toyota Camry
How to setup my LHT854 to route my LG 42LN5300 TV through the speakers?
You probably need to be a bit clearer as to what you want. But the f (function) key on the unit allows you to change the input To ARC if you have it set up. If you switch off your TV /stereo using the TV remote only this should shut down both. When you turn it on again both should turn on with the sound routed through your stereo ( when you turn on you need to wait a short while while the stereo starts up)
Aug 12, 2014 | LG LHT854 Theater System
Machine doesnot start
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jan 19, 2013 | Kenmore Washing Machines
I need to put the belt back on my 94 thunderbird and forgot how it goes. I need a visual diagram
The serpentine belt diagram is usually under the hood on the radiator support. If it's not available you can figure out the routing with the following information. (1) the belt will wrap nearly all the way around each pulley; it will not merely wrap around a small area of any pulley. (2) The ribbed side of the belt will go into grooves on the pulleys, and any pulley without grooves is driven from the back or flat side of the belt. The tensioner pulley is almost always smooth and driven on the back side of the belt. Hope this helps.
Jun 16, 2011 | 1994 Ford Thunderbird
Check engine seems to only pop on when driven on the highway.Been driving it for weeks and it hasnt popped back on since my last highway travel, untill i drove on the highway today. I brought it to...
they could b referring to the vehicle speed sensor, which senses vehicle speed for input to ur ecm and not to ur speedometer. u most likely have 2 sensors with almost same name. their located on ur trans, an some sense input shaft speed an the others sense output shaft speed..... good luck hope this clarifies it for u a little bit
May 01, 2011 | 1999 Saab 9-5
My chevy monte carlo year 2003 the engine just recently started knocking..we put oil in but its still having the problem can you please give input
Before you put the oil in, did you check the dipstick to see how much oil was in the engine? What did it show? If there was no oil showing on the dipstick, you may have driven it without oil. If so, the engine may be permanently damaged from lack of lubrication.
Jan 30, 2011 | Chevrolet Monte Carlo Cars & Trucks
Speedometer not working service engine soon light on
I would guess there is a relation between the inop speedo and the service soon light being on. Push OFF and WARM on the climate control panel and hold down together for 5 sec to read codes.engine and transmission require speed input to set engine/trans parameters accordingly. The car car is safely performing in a back up mode until repairs are made
Apr 04, 2009 | 1993 Cadillac Seville
2004 BMW 525i Active Steering problem
The Active Steering system uses a Papst brushless dc motor to rotate the cage (ring gear) containing the planet gears a planetary gearbox at the bottom of the steering column. The motor effectively changes the steering ratio by increasing or decreasing the amount of gearbox output rotation relative to changes in the steering-wheel angle input. The resulting ratio depends on the speed of the car. For instance, a low 10:1 ratio gives high maneuverability for parking in tight spaces, with less than two turns of the steering wheel, lock to lock. To track straight at highway speeds, where even a small steering input can produce a quick sideways acceleration, the electric drive boosts the ratio to 20:1. Cars without Active Steering typically have ratios halfway between (specifically 14.1:1 for the BMW).
Now, if your active steering does not work , the car reverses back to power steering and the ratio is 15.1:1 so the car can be driven but the "active steering " is not working and still needs to be fixed.
It the unit needs to be replaced and your car is not under warranty, the repair cost may reach 5000 dollars.
Aug 29, 2008 | 2007 BMW 525xi Sedan
Navman iCN 520 GPS Receiver Logo
162 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
