I have a front load kenmore washer that will not spin
I have a front load kenmore washing machine, the door is looked and the belt is good. The machine will not spin any advice?
    Genius:
  • 1,036 Answers
It could be a fault with the main motor. Unplug and remove water supply.
Open up the back to access the motor, removing the top pannel if needed.
Remove the brushes to the motor and inspect for condition. Replace if they are more than 1/2worn.
If you can test the motor windings then do.
Also worthwhile to check the main board for any damaged or heated components.
The problem will be either the motor or control board if it is filling and draining ok - just not spinning.
Posted on Feb 08, 2010
Water will not drain out of front Load Kenmore 44072
Kenmore front loading washing machines will give you years of service. Sometimes things do go wrong, especially after the warranty runs out. Troubleshooting a Kenmore front loading washing machine could save you a lot of money on a repair bill. Before you call a service technician to fix your machine, attempt to resolve the issue through simple fixes first.
Washer Code Messages Your Kenmore front loading washing machine has an LED display that will give you error codes.
Will Not Spin If your washing machine does not spin, check to make sure the door has latched completely. Also remember that if your machine is in the SUD cycle it will not spin until it has eliminated the suds.
Washer Is Noisy
  • If the washer is making noise or vibrating, check to make sure it is still level. If it is out of level you can change this by adjusting the feet. Metal belt buckles and buttons in your laundry could be causing the noise as well.
  • Door Stays Locked After Cycle
  • At the end of the wash cycle, the lock will disengage after about 30 seconds. If it does not, it may be because the machine still detects that the water has not completely drained. Just select "Drain" and "Spin" and let the washer go through the cycle. Your door should unlock.
Nov 03, 2011 | Washing Machines
I have a kenmore 80 series washing machine. During the second cycle it stopped working. It won't drain or spin. What should I do?
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 10, 2011 | Kenmore 24902 Top Load Washer
Washer does not spin, broken belt? kenmore series 70 top load
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 28, 2010 | Washing Machines
I have a Kenmore [2005]front load washer that vibrates severely when in high spin and is quite noisy. I have had the top panel, back panel, and bottom front kick panels off and I can not find any obvious...
you may need to change the bearing on the drum easy way to check is while the door is open try to manually spin it with your hand if you hear a grinding sound then the bearing is gone
Nov 05, 2010 | Kenmore 44102 Front Load Washer
My kenmore 80 series washer wont drain or spin.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 16, 2010 | Kenmore 22422 Top Load Washer
Kenmore Elite Smartwash - error code F dL flashes and washer doesn't start
The reason for "F dl" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
Thank you !!
Jun 14, 2010 | Kenmore Front Load Washer
Washer Glass window in front load door glass is broken.
they should replace it. sounds like problem with unit.proberly only replace door . good luck with it.
Apr 08, 2010 | Kenmore Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washer problem
Does the machine pump water out ? Open the back panel and see if motor is running ? In case motor is running, check that belt is OK. Let me know with your results and I will do my best to assist you to solve your problem, Good luck !!!
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
