Question about HP DeskJet 970cxi InkJet Printer
The paper feed light stays on (middle orange light) and doesn't print
THE PAPER JAM LIGHT WAS LIT WITHOUT A PAPER, I TURNED THE PRINTER OVER AND FOUND A BUG THAT WAS STUCK IN THE ROLLERS, PROBLEM SOLVED , THANKS
Posted on Feb 09, 2010
PC communicates with my HP laserjet 1020 but paper does not seem to pull through and wont print and orange fault light flashes then stays on
nothibg to warry about it just check tonner if its ok then do the servicing and also see for the paper jam chek may be ther e inside paper was jamed yeterday
Jun 07, 2012 | HP LaserJet 1020 Printer
My printer has the blue light on the lightbult and low toner (but ink is fine) - it will not print anything. The stuff sits in the print queue and i have to eventually delete it. The report will print...
My work-around for this problem is to feed paper in manually through the front. I turn the printer off and make sure all paper is out of the printer. When you turn the printer on - and the blue light stays lit (if it doesn't turn it off and wait - I've had to wait quite some time sometimes).. then manually feed 1 sheet of paper in the manual feed tray at the front. When the paper is inserted... you should be fine to print - and keep feeding paper in until you get your job. If you miss - you might need to hit the "continue" (triangle button)..
I've been trying to find out why mine locks up - and why it keeps jamming - but this is a tried and proven menthod - althought it is annoying it might help you for now.. Good luck
Sep 02, 2011 | Lexmark E250dn Laser Printer
Paper will not fee, printer will not print
two cartridge inks at end continually flashing so is this why the paper wont feed?
Apr 21, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
Hp designjet 110 is not printing. paper is spooling then stops, retracts. orange error light is blinking. can't find users manual
check ur orange cartredge
& check ur orange printer head & clean ur printer head
ur problem is solve
because this problem is only cartredge & prinater head
Apr 22, 2009 | HP DesignJet 110 Plus InkJet Printer
Middle orange light stays lit. Paper is not jammed.
The cartridge has a small electrical circuit board on it. That circuitry may be defective so that the printer does not recognize the cartridge. Return the cartridge as defective and try another. If that does not solve the problem, then discard the printer. I've read that most printers are manufactured to only last about three years.
Dec 29, 2008 | HP DeskJet 932c InkJet Printer
Paper feed
Something is stuck in between the
tray and rollers possibly torn paper
in one of the corners
try with just a few sheets of paper
Once you remove the jam
wilthout breaking any plastic
parts it will work okay
Nov 16, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP DeskJet 970cxi InkJet Printer Logo
120 people viewed this question
Seeker5211
Seeker5211
