Question about Welding Tools
My wire feed welder seems to burn back to the tip very regularly....can I clean the sleve with anything? Would a drive wheel being too tight be a possible problem?
    Champion:
  • 225 Answers
You can either turn amps down or turn wire speed up,make sure drive wheels are set for the size of wire you are using,one side is set for example .023 flip it over the otyher side will show .030.
Posted on Feb 09, 2010
My wir burns up at the feed wheel before it goes to the sleve
did you forget to reverse the wire .seems like I read that someplace . many newer ones thay added a switch for that purpose .
May 07, 2015 | Miller Spoolmatic 30a Mig Spool Gun 130831
The wire is slipping on the wheels and not feeding to the gun
check the tension on the spool - is it free to rotate ( but not so free it over-runs when you release the trigger)
check the tension on the drive wheels - are they turning and slipping on the wire?
Do you have the correct drive wheels for the wire size? if you're using .8 wire, you need to be using .8 drive wheels (or the .8 grooves if you have multiple grooves.
is there a kink in the liner? pull out the liner (remove the whole gun attachment, usually the liner will slide out from the end where it attaches to the welder). Blow out the liner with an airgun while you're at it as they fill up with crud.
When you reassemble the gun, slide a lenght of wire up the cord and check that you can push it all the way in freely.
Then when you rig the welder, leave the tensioner off the drive rollers, and push the wire into the gun by hand. you'll feel if there are any tight spots ( usually caused by kinks in the liner).
once you've rigged it, clamp the drive rollers shut and adjust the tension until they feed the wire smoothly. (leave the contact tip off the gun when you rig it as the tolerances are so fine that even the small flattening of the wire where you cut it will usually prevent it from feeding into the tip. Once it feeds properly, reshape the cut end of the wire and attach the tip (don't force it over the wire or you' ll just damage it)
Jul 13, 2012 | Welding Tools
I have had my Pro-MIG 140 for six years, never a problem. Pulled the trigger today, the wire got red hot and melted at the drive gears. Is this a problem with the liner? or something else? Im in the middle...
If you can feed the wire manually(by hand) the liner should be OK. I would replace the tip and verify all the welder connections at the drive wheels. Make sure all the connections are clean and tight.
Mar 08, 2011 | Lincoln Welding Tools
I have a wg2020 campbell hausfeld flux core mig welder I have to turn my wire feed all the way on max to get the wire to feed. It seems like to motor is getting weak. Sometimes it seems to work right but...
Hi:
Sometimes the drive motor collect a lot of metal dust from the environment and it requires a clean up. Take the tensor off and remove all wire, try to apply compressed air into it and then apply WD40 and run it. Make sure your tensor wheel it's not to tight and that you are using the right wheel size for the wire in use. Another problem rely on the gun liner if this one hasn't been change in 12 months, it is time to replace it, or, if it is not kinked at all, try to use clean air to blast out all metal particles from it. (take off you gas nozzle and gas mixer also known as contact tip holder).
Good luck.
If this was useful to you, please vote.
Feb 25, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have a wire feed welder that is not feeding wire fast help
Make sure that wire feed wheels are tight and the tip is clean
Nov 20, 2010 | Miller matic 140 Mig Welding Package W/As...
Drive wheels slip and won't feed wire. tensioner tightened as tight as possible.
make sure your drive wheels and contact tip is the right ones for the size of wire you are using. if your tensioner is too tight it will crush your wire and it will not feed through your contact tip.
loosen off your tensioner and remove any wire that has gone through your drive wheels.
Feb 08, 2010 | Astro Pneumatic Welding Tools
I have a brand new Lincoln pro mig 140. Took it out of the box and set it up yesterday. After approximately two hours of mild steel welding today the wire drive roller quit working. I've tested the...
I'm having a problem with the wire feed on my Lincoln Pro Mig 140. The wire feed speed is not consistant. It seems to be slipping even though the tension is tight. Any solutions?
Oct 18, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Power mig astro power 110 burns wire off at tip
I have the same welder. Worked well for 15 years until the drive bearing stopped spinning. I cleaned and oiled the bearing and it has been working like a coon on the farm since. Nice 120 volt welder....
Apr 02, 2009 | Welding Tools
Flux core welders are burning up tips, insulators, and leads
Try to turn up the wire feed and the volts and pull the cup 1/8 inch past the tip
Nov 30, 2008 | Campbell Hausfeld MIG / Flux Core Wire...
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Welding Tools Logo
335 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
