Question about Pyle PLD57MU Car Video Player
Break the break!!!
How do I bypass the parkbreake safty system on the Pyle pld57mu?
  • brikka Mar 22, 2008
    i have the same problem please help!!
Connect the green wire to the grounds.
Posted on Jun 12, 2009
Blue power antenna wire is causing radion to stay on all the time what should I do
The 3rd wire is coming from the bypass switch. I have the solid blue wire from the unit the blue and white from the jeep and the bypass wire all hooked into one. Is there another wire I could hook the Blue wire too I had two yellow wires coming from the radio one is with the yellow wire from the car the other is capped off could I unhook the blue from the blue and white/bypass and hook it to the other yellow possably?
Apr 15, 2014 | Pyle PLTS78DUB Car Video Player
When i put in a dvd the screen stays blue and says "warning stop watch video player" how do i get the movie to play?
their should be a safty wire run to the emergency brake that allows video only when the brake is set to bypass it you would need a relay wich you can get at autoparts store check out youtube for video on how to wire the relay
Jun 25, 2011 | BOSS AUDIO SYSTEMS BV7320 Car Video Player
Tracker will stall when I release the break. It is not the seat safety feature as double checked that. It has something to do with the release of the break? Help
Could be .Some have a 3wire system.Before you change the sw. follow the wires to the next sw./safty devise.could be deck sw. szm230
Apr 15, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I am about to install my boss bv8962 unit into my vehicle but I want the parking break safety feature bypassed. What do I do differently during installation so that my passengers will be able to watch tv...
Yes, you can bypass parking break feature by connecting the corresponding wire of BV8962 to ground, also you could add a 3 pin toggle switch to get a normal and bypass mode switch, this can be wired of this way, the common pin of toggle switch to your video unit, at the other pin, it could be connected the parking break wire (normal mode) and the remaining one to ground (bypass mode).
Feb 26, 2011 | BOSS AUDIO SYSTEMS BV8962 Car Video Player
AVX-P8DVD need to know how to bypass the parking break safty feature
Take the Park Wire, via a 100 - 1000 ohm resistor, to stop any potential damage if wrongly connected, AND this lead is taken, either to + 12 volts DC, always ON... or - 12V DC or Earth. Some also work through the Stop Lights Bulb resistance... But I am sure you get the idea.
Mar 02, 2010 | Pioneer Car DVD AVX-P8DVD - Premier 6.5"...
Why wont my car turn over unless i press the gas?
The break safty switch could be mixed up with the break safty switch.If the car will start without you steping on the break,the wires are mixed up in the harness or the car was put together with the break safty switch on the gas insted of the break.
May 11, 2009 | 2002 Chevrolet Impala
The break lights of Santro is glowing continuously
you got a short in your wiring harness it may be cut due to the impact
Jan 02, 2009 | Pyle Pl3156rd Led Break Lights
Car will start but gear shift is locked
follow instructions in manual for SHIFTLOCK RELEASE
Turn off car.
Engage Parking Break
Take ignition key and put into shift lock release slot (near gear shift)
Push down on key and at same time MOVE gear shift to neutral.
Remove key, start car as normal and disengage parking break...
good to go.... mechanic can replace/repair if this is an ongoing issue: $85 I read somewhere...but heard it's not hard to do yourself for $35 someone else wrote.
Goodluck
Jul 15, 2008 | 1996 Honda Accord
Pyle PLD57MU Car Video Player Logo
78 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
