Question about Singer Sewing Machines
Thread tension adjustment Singer Slant-o-matic Model 500A
The tension adjustment for the thread from the spool, (not the bobbin) on a Singer Slant-o-matic Model 500A is way too tight.
I had a new spring put on but it still is too tight. I have taken it apart, but haven't been able to figure out how to ease the tension enough. A schematic of how it should look would be great.
Is the repair manual still available?
  • prutherford1 Feb 08, 2010
    I did not make my self clear, apparently.
    I have taken the entire tension mechanism apart.
    I know very well what good tension looks like when it is working right.
    I have used the machine for a few years.
    I know very well how to thread the machine per the diagraham on the machine.
    Do you know how to reassemble the thread tensioning device with its plates, springs, and washers?
    That is mystery I need to solve....and why a schematic would be nice if available.
    Thanks for your initial reply.
    Brigadier General:
  • 3,917 Answers
Loosen sewing thread tension by turning the machine's tension adjustment knob counter clockwise. All though the thread tension may already be too loose, back the sewing thread tension knob out. Be careful not to turn the knob accidentally so much that it falls out of the machine. Check the sewing machine thread from the spool to the sewing needle to make sure the sewing machine thread routes are correct through all of the machine's guides.
Now get a piece of scrap or test material about two feet in length. Place the material under the sewing needle the same way as in a normal sewing process.
In the second step below, look for, while sewing, if a slight noticeable pull to the left occurs as the material passes the sewing needle. When a slight noticeable pull to the left occurs, the machine tension is at proper adjustment. Do not tighten the machine's thread tension knob any further, to prevent any harm to the machine.
Now to begin the second step, turn the machine's tension adjustment knob, one quarter of a turn clockwise. This will tighten the sewing thread tension. Now sew approximately a dozen stitches through the material.
As the material passes the sewing needle, watch to see if the material has a slight noticeable pull to the left. No slight noticeable pull to the left suggests improper sewing thread tension. Turn the sewing machine tension adjustment knob one quarter of a turn clockwise again, to tighten the sewing thread tension, and then sew another dozen stitches.
Keep repeating the process of quarter turn increments clockwise with the sewing machine's tension adjustment knob. Then sewing a dozen stitches, until a slight noticeable pull to the left occurs as the material passes the sewing needle. Once the material does this, the sewing machine thread tension has reached proper adjustment.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 08, 2010
I have dismantled the thread adjuster. can someone help me to put them back in the correct order please.
Posted on Jul 21, 2013
New singer plus one.....constantly stopping with message top thread broken (which it is not) but there is a nest of thread from the spool underneath...have rethreaded from spool and bobbin # of times
bird nesting of the bobbin thread is a result of the needle thread tension not tight enough
increase that tension up and the message may be eliminated
Nov 20, 2016 | Singer Sewing Machines
My Singer Slant-o-Matic 500a sewing machine will not wind a bobbin. The winding pin barely started to turn, then no motion. Also, the wheel doesn't seem to tighten.
Your machine is an older mechanical machine, so have you cleaned and oiled it recently? Usually, older machines' oil will gunk up over time and stop things from moving like they should. Use only Fresh, good quality sewing machine oil. Do NOT oil belts, cams, rubber, or plastic parts. Slowly rotate the handwheel and place a couple drops of oil every place where metal rubs metal. To speed up the process, direct hot air from a handheld hairdryer into the internal metal parts.
singer 500a bobbin winding
How to Inspect Rubber Bobbin Winder Wheel Singer 500 503 Sewing Machine
BrianSews Singer Slant Matic 500a the Rocketeer
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwjqkcWf7KrMAhVB4GMKHVwoA-MQFggvMAQ&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F1308_500.pdf&usg=AFQjCNFEBkPQttXzueRCWGluOe-YBmF5Wg&cad=rja
Apr 23, 2016 | Singer Sewing Machines
Singer 401
Hi Sara
If you don't have the manual for your Singer 401 you can find it online for FREE. Lots of people try to sell these but they are usually available somewhere online for no charge. Here is the link to the one I found:
http://www.ismacs.net/singer_sewing_machine_company/manuals/singer-401-slant-o-matic-sewing-machine.pdf
There is a section on adjusting tension for the needle by turning the tension knob. Sometimes you have to try a test run on a scrap of fabric. If it is too loose then turn the tension to a higher number, if too tight turn to a lower number. Probably start in the middle around 4 or 5 The bobbin tension is adjusted with a screw. Then manual has some illustrations. Hope this helps.
Lola
May 28, 2013 | Sewing Machines
How do you adjust the bobbin
Hello
Set the tension on the sewing machine for the weight of the material you want to sew. The tension setting shows in the stitch on the material. Use the chart on the machine that matches types of stitches with suggested material tensions. An example of this is, the stitch to sew jean material is different than the stitch to sew silk.
Take the bobbin and wind the thread around it. Make sure the bobbin is empty and don't fill it too full of thread. A bobbin filled too full won't stay tightly spun.
Thread the string evenly on the bobbin. Move the thread back and forth evenly and in layers that are level. Many Singer sewing machines have a bobbin winder on the top of the sewing machine, and the consistency of how it threads can save you frustration later.
Find the hole on the bobbin that is located near the inside spindle of the bobbin. Take the thread sitting on the sewing machines spool and insert the thread in the hole from inside the bobbin to the outside. Set the threaded bobbin on the spool designated for spinning on the top of the sewing machine for some Singers.
Turn the side drive wheel slowly until the threaded bobbin has a layer or two of thread on it. Push down on the drive peddle and fill the bobbin, but don't thread it to the very edge. If the bobbin is too full the thread will release erratically. Cut the thread from the spool.
Drop the bobbin into the bobbin case under the area where the needle sews the material. Close the case and turn by hand the side wheel drive until the bobbin threads into the sewing machine. You can tell when the bobbin is threaded by the tiny piece of thread that juts out of the bobbin case where the needle goes up and down.
Grab the thread with your fingers and pull it out approximately 4 inches. Your bobbin is now spun and threaded.
Aug 02, 2011 | Singer 1120 Mechanical Sewing Machine
Someone gave me a portable Singer sewing machine that is practically new. However, when I sew a fabric, the top part is stitched well but when I turn the fabric over, I see that in the stitching underneath...
It definitetly sounds like a tension adjustment, make sure the top tension is about 4 or 5 and you should only be able to pull the bobbin thread through with slight resistence, if it is too tight slacken the scew on the bobbin case about a quarter of a turn at a time and test, keep adjusting until you get it right.
Jun 18, 2010 | Singer 14SH654
Singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
Sep 21, 2009 | Singer 57817 Computerized Sewing Machine
Bobbin thread bunches up in machine
remove bobbin; remove spool; look on side of bobbin case for a tiny screw (bobbin tension) adjust screw untill top and, bottom thread lock is the same
Sep 06, 2009 | Singer 2950 Mechanical Sewing Machine
SInger buttonholer for a 60's slant needle..thread globbing ...
Personally I don't have the experience with a buttonholer attachment, however I do have several slant Singer machines. I'd suggest that you go to yahoo.com and click on Groups. In the search box put in singerslantsewing and join that group. Members are a diverse group of Singer enthusiasts, some repair guys there, and they are happy to assist, should you join and post your problem. There are other groups for Singers, but this group is dedicated to the slant needle models.
Nov 20, 2008 | Sewing Machines
I need to thread an elna air electronic su sewing machine
that's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
See this image.
Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
Aug 24, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
608 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
