Question about GE Cordless Dual-Line PC Phone for Skype VoIP
GE Skype phone doesn't connect
GE Skype phone indicates "PC not available" Using Windows XP home. USB port works. Rebooted computer - didn't help. USed the phone on a different computer previously - not an option now.
2 Suggested Answers
SOURCE: GE 6.0 Dect 28300 not working in Vista w/skypemate
Uninstall skypelink and remove the usb cable of the phone from the computer. Reinstall, and after install, plug in the usb cable.
As per installation instructions, you shouldn't plug in the USB before you have installed the software....
Posted on May 13, 2009
My computer windows xp 32 bit doesn't recognize my samsung sch s738c phone
I am assuming you are connecting your samsung phone to the Windows XP computer using a special cable that plugs to USB port. You should also have the PC connection driver software available from Samsung installed on your computer.
Please refer this site to download the software driver and manual.
Hope this helps.
Samsung Galaxy Centura Straight Talk
Aug 14, 2014 | Samsung Cell Phones
Tip
How to fix ?USB device not recognized? error in windows
Are you getting a “USB device not recognized” error whenever you plug in a USB mouse, keyboard, or other USB device? I love USB and have 5 ports on my computer so that I can connect my mouse, keyboard, camera, phone, and printer to it all at once!
However, last weekend, my computer stopped recognizing my USB devices! The strange thing about it was that the USB ports were not bad because all of my devices were still getting power to them. I could still charge my cell phone without a problem!
So I started with the normal fixing methods, including uninstalling the drivers for my devices and reinstalling them. That didn’t work! Next I tried System Restore thinking that maybe I had installed something and it caused a conflict with the USB system drivers. That didn’t work!
I read online that in order to fix this problem I should go to Device Manager and uninstall all of the devices under USB Controllers. Restarted the computer, reinstalled the USB drivers, but the problem STILL did not go away!
You may also see in Device Manager that the device shows up as an “Unknown Device”. 42b721d.png
So how did I finally fix the problem? Well, apparently it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
on Jul 08, 2010 | Computers & Internet
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Computer can not learn my gb 230 when it's connected to him what can i do?
I am going to assume you are using a Windows based PC.
Now I have never come across this problem before but this should help connect more or less anything to a computer.
Switch off your phone and make sure your computer is turned on, then turn your phone back on. Connect your phone to your PC and there should be a message that appears on your mobile phone asking to go into mass storage mode, you want to select yes.
If this doesn't work then you can try other USB ports on your computer or you can open your connection wizard and go through the USB option this should make your computer cycle through all your ports until it sees something.
I hope this helps.
May 25, 2011 | Cell Phones
The pc is unable to detect the sansa disk
If you are using Windows XP: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
Refresh the driverd
1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Apr 03, 2010 | SanDisk Sansa Clip MP3 Player
Mar 24, 2009 | GE 28300EE1
Samsung sgh-j600v
hi im josh in cebu phils.may i help you?
Friend if not recognized by the pc im sure the problem is in the connection because XP O.S. auto detects usb.
To solve the problem:
1.Check the usb port of the computer you are using
2.Check the usb cable from your phone to pc be sure there is no cut.
3.Check the usb port of your phone so as the connection. and the setting be sure the usb is enable.
Good luck friend hope i helped you.
Mar 14, 2009 | Samsung SGH-J600 Cellular Phone
Lifecam VX-6000 microphone in Windows XP stopped working
you need to restore your PC back to the date when it is working.pls.. rate.ty
Jan 27, 2009 | Microsoft LifeCam VX-6000 Webcam
GE cordless phone 28300EE1-A driver
Here you go:
Click on the link below and then look for "Download Skylink 2-in-1 Phone Utility"
http://www.home-electronics.net/ge/pc/viewPrd.asp?idproduct=18
Dec 10, 2008 | RCA General Electric 28310EE1 Skype IP...
GE Cordless Dual-Line PC Phone for Skype VoIP Logo
62 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
brian soufane
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
