Question about Agri-Fab Agri - Fab Snow Blower - 42"
Wont start unless i pour gas in carb throat, MTB snow blower. float ok, gas is good to feed .MTB snow blower. I'm sure carb problem, what to do next?
  • bassinking Feb 09, 2010
    gas is filling bowl. gas shuts off by way of float. gas not getting to cylinder. I'm snowed in can not get rebuild kit
  • 478 Answers
Depending if you have a ajustment on the bowl you will need to ajust to get the right mixture if this will not fix your problem then you will need your carb rebuilt
Posted on Feb 09, 2010
Yard Machines 31A-2M1A700 21-Inch 123cc OHV 4- it wont start.
Just pouring the old gas out is not enough in most cases.the fuel, fuel filter if equipped and the carburator are contaminated and or gummed up were it will require a complete carb. rebuild
Feb 14, 2015 | Garden
Snow blower wont start
clean the fuel out and the carb , make sure you are getting spark close the choke to start then shut if off or it will foul the plug
Feb 17, 2014 | Toro Snow Blowers. Power Clear 18 in....
Strong gas smell after using
make sure its not leaking out of the bottom of the carb
if so clean carb
float may be sticking
Jan 25, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
hi
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Joe
Oct 01, 2012 | Tecumseh Garden
Had one answer but i failed to mention that since the trk .had set up so long and would not run i used a gallon jug for a fuel tank and fresh gas .I also used clear fuel lines and could see the pump ****...
Lightly tap the CARB after or while cranking.If the vehicle has been in-op, the fuel in the bowl would have gone bad or dried out leaving a degree of corrosion behind. After soaking in fuel overnight, Tapping may permit the float to drop opening the needle valve. Chk the accelerator pump by working the throttle linkage. kEY OFF! lOOK INTO THE CARB TO VERIFY ACCELERATOR PUMP FUNCTION.. If you are pumping fuel, it should start. If no fuel, The pump may have dried up. Again, a good soaking overnight may swell up the plunger in the pump enough to get it working. Worse case scenario if none of this works is rebuild the CARB. Good Luck and be careful. _N_
Apr 05, 2011 | 1987 Dodge Raider
Jet pulse carb will not feed gas to engine after start
Make sure the gaskets were installed correctly.
Oct 08, 2009 | Garden
I bought a 1985 GS 550 LF. It had been sitting for a year, so battery was dead tank & carbs were dirty, clutch cable was broke. I fixed the clutch cable, cleaned the gas tank, bought a new battery and...
Gas pouring out of the carbs means the float pin are not sealing in thus the over flow.
Go a little down thn .77in , best would be to bench set them.
Take a pipe say from the tank to the feed pipe of the carbs (best would be to remove the tank and place it higher on your work bench to get the gravity flow to the feed pipe of the carbs)
Allow the flow to the carbs and monitor the over flow, see which carbs over flow, remove the float bowl and reset the float and let it go a little less thn .77in, refit the bowl and retry the feed in and recheck..you will come to a point where gas wont over flow, open the bowl and see the level of the gas , it should be covering the jets, but remember that since you will have the float bowl out the gas will show low as when its submersed, the jet stem in the float bowl pushes the gas level up so dont get mixed up when you see the level low , i am sure you will be able to judge it for yourself.
I had the same problem in myYamaha(seca) XJ750R !981and finally managed to win over the problem going over it the way I explained.
Hope this helps! Good luck.
Jul 14, 2009 | 1984 Suzuki Gs 550 L
I have an older mercury 4hp 2 cyl. Wont run. got lots of spark, gas was running out of carb, took it off, cleaned it out, but I might have the spring on the float in wrong. does anyone have a scematic?
Ok, if you have fuel coming out of the throat of the carb then you need to readjust the float level. On that engine the best way to set the float level is to remove the carb. Remove the fuel bowl. Turn the carb upside down so the float is on top of the carb. You want to bend the tang (the piece that seats the inlet needle) so that if you are looking at the float it sits perfectly level. Once you reinstall the bowl and carb be sure to adjust your idle mixture and try it again. If it still spews out of the carb throat then take it back apart and do it again. If the inlet needle point is worn at all then you need to replace it so that it seats good. But if you set the float it is level when the carb is upside down you should not have a problem. You can put your faith in the fact that every spring I rebuild about 5 outboard carbs a day from people letting fuel sit during the winter.
Jun 07, 2009 | Boating
Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Dec 18, 2008 | Honda Chipper Blower and Vac: 5.5 Hp Gas
Agri-Fab Agri - Fab Snow Blower - 42" Logo
288 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
