Machine is not recieving water supply
After setting timer when machine is started it is not recieving water
  • olenyatko Sep 30, 2008
    the same trouble. yet checked all filters and still the water does not get into machine.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
Check tap and also check fill hose for twist trap or kink
Posted on Feb 22, 2008
Trying to install timer on Maytag coin-op washer. Did something wrong It filled with water and then stopped
Check voltage supply to the timer, make sure power is still supplying
the timer motor when the water shuts off, at which time if the timer motor is powered will close the next set of contacts and start the wash
cycle. Make sure you have the correct timer.
Also check the safety switch for the lid, if the lid does not close that switch or if its bad, the wash cycle will not start.
Oct 23, 2012 | Washing Machines
Whirlpool LF Error code
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
    Hello there:
    If your cycle does not complete or The cycle doesn't advance
    When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
    Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Stuck in spin
    Hi!
    If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
    It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
    Do rate the solution as FixYa and revert for further clarification.
    Thanks
    Rylee
    Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Soon as i set cycle and swich on door light flashes open
    hi,
    Thanks for your question.
    Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
    Washing Machines Logo
    79 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
