Question about Energizer Camping, Backpacking & Hiking
How to change the batteries on the TUF4D1
How to change the batteries on the TUF4D. It's an energizer hard case lantern. I can't figure out how to get to the battery case
    Problem Solver:
  • 16 Answers
The front outer rubber cover is removeable. Once you take it off with your fingers, the front unscrews revealing a two piece battery case. Squeeze the top flanges together and lift out, then the battery case shown in the box just lifts out.
Posted on Feb 12, 2011
    Problem Solver:
  • 6 Answers
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Posted on Jul 27, 2012
Energizer WeatherReady lantern came with batteries; worked once. Can't unscrew the top to change batteries. Possible battery corrosion? Is there a workaround fix?
Mix water and baking soda together until baking soda is dissolved.
Take a small baking pan or a bowel with a flat bottom and place the lantern in a vertical position, bottom down and slowly pour in the baking soda solution so the solution is 1/4" above the battery lid so the solution can soak into the threads of the lid. Let sit overnight. Next morning, slowly lift the lantern out of the solution without tipping it keeping it vertical, and slowly unscrew the lid over the sink. Keep in mind there will be solution inside the lantern when you first open it, so be careful not to tip it until you dry out the inside.
Aug 31, 2016 | Energizer Camping, Backpacking & Hiking
HOW TO INSTALL BATTERIES IN ENERGIZER HARD CASE LANTERN
Unscrew the entire front light from the casing. The battery is underneath.
Aug 24, 2015 | Energizer Camping, Backpacking & Hiking
Change the battery in the hard case
Start by unscrewing the lense cap retaining ring. Pinch and remove the clip from the negative (-) spring on the battery. Remove battery and slide new one in. Reconnect wire connector in between spring on the negative side of the battery. Note: some lanterns have a v'd plastic ear on the back of the reflector so when you go to screw the reflector back on, align the v'd ear with the plastic bar inside the case under the handle and slide it together until you can screw the retainer ring on.
Feb 28, 2015 | Energizer Camping, Backpacking & Hiking
How do I get to the bulb?
Unscrew the head assembly. In the back of the assembly is a small plastic nut. Unscrew this and the bulb should fall out into your hand.
Nov 01, 2014 | Energizer Eveready Utility Lantern Uses 6V...
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits...
Apr 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
How do I change the bulb of the 6V Eveready Lantern?
If it is the yellow floating lantern you have to remove the black plastic stub on the underside of the reflector using needlenose pliers to wiggle and slightly pull until it releases and the bulb will come out.
Jan 06, 2011 | Energizer Eveready Utility Lantern Uses 6V...
My TUF4D1 flashlight does not have a twistoff cap opposiite the light. Unless I have to take out screws?? I still can not find out how to get into the battery compartment of this flashlight?? any body...
Oct 02, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
Trying to figure out how to change batteries in a energizer hardcase lantern tuf4d1.
the bottom section turns and the upper section with the handle is just a shell. these are very good lights
Nov 13, 2009 | Hand Tools
Camping, Backpacking & Hiking Logo
1,665 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
weirdtop
Tom Chichester
Jean DeLauche
Jean DeLauche
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
