Question about Parat 1:32 Scale Diecast Replica: 1920 Ford Model T Cargo Truck
I have a ford tractor and hydraulics are slow
I have a ford tractor and the hydraulics are very slow. What is the problem?
    Scholar:
  • 68 Answers
Not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Posted on Mar 11, 2010
    Problem Solver:
  • 6 Answers
Wrong hydraulic oil. The oil could be to thick at this kind of year, so there will be a lot of resistance when flowing. If you don't have these problems in summer, it must be it. Check the needed oil type, viscosity and viscosity index in your manual. Thats all I can imaging.
Kind regards Marcel van ****
Posted on Feb 10, 2010
Ford 7810 series 2 hydraulics have gone very slow have pressure tested tractor and it is OK until you rev it up the pressure goes oil sound like it is sergin in back end of tractor oil level OK ?
Best advice is for you to list this in Lawn and Garden or Construction equipment section for Tractors. There is a valve knob on a 4000 series that proportions hydraulic flow from more in back than front depending on the setting. If you have a front loader or if you have rear attachments you can get more action on the end you want. On a 4000 the knob is by the right heel of the driver. Could work like this for 7810.
Jul 20, 2017 | Ford Cars & Trucks
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
Nov 14, 2016 | Ford Garden
Rear hydraulics on my ford 4100 keeps moving-either up or down. does not stay where i want it. Is this operator error or is there something wrong with the tractor?
possible the float control of the hydraulics
that allows what ever is attached to maintain a ride height and not dig in when the front of the tractor go over a rise or to cut/dig light when the front goes into a dip
if you operators manual doesn't show it or you don't have such a manual, ask the local ford tractor agent
May 05, 2016 | Ford Garden
My hydraulics are slow 3 point hydraulics get slow when steering used
Hydraulic steering, I assume.
Could be very cold weather and fluid is cold and thick. Could be a clogged filter. could be old hydraulic fluid
Feb 07, 2016 | Garden
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
How to check the hydrolick fluid on a 1972 ford 5000 it has no dipstick I just got this tractor
Ford Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages4/
Helpful information and resources on Ford tractors from SSB Tractor, a leading provider of tractor ... tractor pumps oil but won't pump hydraulic fluid ..... 1972 Ford LGT165 lawn and garden tractor hydraulics ..... Ford 5000 transmission oil level
Aug 17, 2015 | Ford Cars & Trucks
Does rear end oil and hydrodaulic fluid go in same reservoir
Ford 8n's use a commion sump, rear end, transmission and hydraulics. Ford called for 80 or 90 weight gear lube depending on temperature (winter/summer) about 5 gallons The link below is a great article on proper oil and maintenance....Hope this helps...
< http://www.myfordtractors.com/hydraulics.shtml > Ford Tractor Hydraulic System
Jul 26, 2014 | Ford 8N Tractor
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Apr 11, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
Nov 16, 2009 | Plumbing
Parat 1:32 Scale Diecast Replica: 1920 Ford Model T Cargo Truck Logo
1,042 people viewed this question
Top Parat Toys Experts
ray gallant
Are you a Parat Toy Expert? Answer questions, earn points and help others
