Question about Nixon Watches
How to adjust the watch band on the nixon private ss watch
slp11508
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: tighten wristband of the Nixon Watch , remove links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: Nixon Watch band
Perheps this will help though it's not the same company http://www.allamericanwatches.com/site/626101/page/182605 Or get in touch with your local dealr you have a 2 year warraty on that watch http://www.nixonnow.com/za/NNS?PAGE=FAQ&MENU_ID=14
Posted on Jul 03, 2007
SOURCE: Watch Band Adjustment
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
Posted on Jan 10, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
Job done!
Posted on Jan 10, 2009
What type/kind of battery do i use to replace in my super hero ii ss black nixon watch
Take your Nixon watch to a jeweler to have the battery replaced.
Apr 24, 2017 | Nixon Watches
COULD YOU HELP ME PLEASE
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
http://online.nixon.com/us/en/repair-center
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
Hi, iam looking for nixon private ss gunmetal extra links!!! thanks a lot!!!
Contact the manufacturer with the model number. They will be able to provide you extra links.
May 12, 2011 | Watches
How do you adjust the band to fit a smaller wrist
You have to take out the small pinions that interconnect the different small pieces of your wrist band.
If you take it to a watch repair shop he probably won't even charge you for it.
Mar 01, 2011 | Nixon 51-30 Chronograph Wristwatch
I need a new watch band for my Nixon Scout watch
Try contacting a Nixon service center.
You can locate your nearest service center by going to their web site "www.nixonnow.com/dealers/" and filling in your details.
Mar 02, 2010 | Watches
Add link to the wrist band on my Nixon "The Player" watch?
you can find a exper in you real life or in the watch shop..
Dec 28, 2009 | Nixon Player NIX0003 Wrist Watch
Watches Logo
822 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
