Question about Dell Vostro 1510 Notebook
Cd player won't eject ,how can I get the cd to release cd.
  • 111 Answers
Look at the front of the CD drive, there should be a small pin hole. Take and straighten out a paperclip. Push the paperclip inside the pin hole and lightly push. The tray should open slightly. Then just manually pull the tray out and remove the disc.
Posted on Feb 08, 2010
Show a diagram on how to get cd stuck in 2006 f150 out. Cd stuck and tried but it won' come out
Look to see if there is a tiny hole on the front of CD player just under the tray.that is the access point for a paper clip.if there isn't one...try turning ignition off then whilst holding the eject button turn on the ignition and do not release eject button.
you may need to try this several times.what you are trying to do is beat the cd from trying to read the cd as this seems to over ride any eject commands on some machines.if all of the above fail you may need to remove entire unit from dash to gain access .
Feb 12, 2015 | Ford F-150 F150 Extended Cab
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
How can the cd player be fixed when it won'r eject a cd on my Mac computer
try ejecting in Itunes. it has a eject button that sometimes overrides the player
Oct 26, 2012 | Apple iMac Computers & Internet
My computer won't play CD/DVDs anymore. It's like there isn't a driver?
Most HP CD players eject. Turn upside down release. Pop out and reseat the whole player.
Sep 30, 2012 | HP Pavilion dv4-4270us Entertainment...
CD Player keeps ejecting the CD
Either Cd is problematic or lens inside of cd player is covered with dust. There is no way of properly cleaning it unless you remove the cd player out and disassemble.
You may try cd cleaner kits but ususally they cant help.
Nov 25, 2011 | Cars & Trucks
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
Cd won`t come out when i push eject button.
If you dont have a cd inside the player, Then use a spare cd and cover it up with a thin,soft and clean cotton cloth and move it back and forth in the cd player.This problem occurs when the ejctors get dirty.Make sure the the player is in the OFF position when you do this.If you have a cd insde then you will need to eject it by force using a vey thin screw driver and prying the cd to make it eject.
Thankyou,
Mohsin Idrees Khan.
Apr 08, 2009 | Panasonic CQ-C1100U CD Player
CD stuck in my car CD player and cant eject it when i hit the ej
it may be you have a paper label on the cd most car cd player won,t handel paper lables not enuf room as for getting it out try this get a light and see if you can see the cd if so take a pop sickle stick with a small amount of super glue on tip and be vary careful put the pss in to opening to the edge of cd let set for a few seconds then try pulling it out when pushing eject donot use but vary little super glue i have done this on some cd player
Mar 26, 2009 | Car Audio & Video
CD stuck in tray for DXZ648RMP player
Figure out what fuse controls the CD player and pull the fuse out for a minute (or more), then replace it (theory being that the fuse acts as a reset button). If you cannot find the fuse, you can disconnect the negative battery cable, but you'll lose your radio and other settings. This trick seems to have the greatest chance of success overall.
Turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again).
Try using some tweezers, needle nose pliers or hemostats (every tool kit needs a hemostat or two!) to pull the CD out while pressing the eject button with power going to the player (theory being that the disc is so slick the player can't eject it without help). Some people report success just by pulling the disc out with the tweezers without power to the player and without pressing the eject button.
If your player has a small hole in the front of it, like most personal computer CD players do, straighten a paperclip and push the clip straight into the hole to manually release the catch. Some players have a groove under the CD door instead of a hole. Look for a hole about the size of the paperclip and don't mistake an emergency release hole for an earphone jack.
Jan 23, 2008 | Clarion DXZ648RMP CD Player
Dell Vostro 1510 Notebook Logo
284 people viewed this question
Alun Cox
