Question about M-Audio Fast Track Pro External Sound System
Suddenly sound off. when i any swtich on any electric box.whats the problem.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Youre electric box consists of a certain circuitery of parallel and serial resistors and capacitors.... when u switch on any other switch from the box the newly made connection offers less resistence to the one ur applying from the sound system , so the preference of current is to flow through an easy way out and hence makes ur problem.... for solution i would firstly suggest u to always use a seperate connection line for heavy power consumption devices.... my answer will beproved if u replace that speaker system with some other appliance of low voltage ... now apply any other connection the low voltage appliance wont stop
Posted on Feb 08, 2010
Nordyne M1MC 070A BW- LED light constant blink. Says "false flame" or "internal control fault". What could this be? Bad limit swtich?
Sounds like a bad board. If this is electric heat you can check continuity across the limit switches with a multi meter. Turn power of to unit and remove wires on each side of limit to test. Really could be a number of things. Good Luck.
Mar 27, 2017 | Heating & Cooling
While driving my 2004 Toyota matrix,the engine suddenly went off and an electrical technician checked up the fuses,fuel pump and plug and said he thinks the problem is likely the brain box.Can one help me...
how good you know your car and its sounds? if when it turns over sounds weird, like hollow, then it is likely that your timing chain broke.
Dec 16, 2014 | Cars & Trucks
Electrical
This type of electrical fault is always hard to find, after you cleaned the fuse box everything worked for two days, sounds like a bad connection, because it is warrning lights AND heated seat two different circuits, check all connections again and check all the EARTH connections these are often missed.
Aug 27, 2012 | Lincoln Cars & Trucks
What is error code 8071053D
It could be that the console is not correctly syncing up to the network properly. This can happen in a number of ways, such as electric power issues that caused the console to turn off-and-on suddenly.
To solve it, you might have to do a hard reboot of the console. This is what to do:
  1. turn off your PS3 by using the power toggle switch at the back of the console and then unplugging the power cord.
  2. Once you do that, power off your modem (also the router if you have one as well) by unplugging the power supply.
  3. What about a minute or so then plug back your modem. Wait for it to sync for internet access.
  4. If you have a router, plug that in next and wait for it to sync as well. Otherwise skip to the next step.
  5. Once your modem and router devices are back on and you have Internet, go ahead and plug your PS3 back and turn it on.
  6. Access the Network Settings menu and see if you can create a new connection.
Mar 09, 2011 | Sony Playstation 3 (PS3) Console
I have a Kenmore Elite electric dryer that we purchased in 2002. It suddenly stopped working - no light inside dryer, drum doesn't turn it is like all of a sudden there is no power to the appliance. My...
Sounds like you need to replace your electrical breaker in the main control box of the house that feeds the dryer. You should get 120volt on each leg coming into the dryer. Good Luck, I hope this helps Please rate me, Thanks
Dec 26, 2009 | Kenmore 63942 Dryer
Won't start or heat up
Check your breaker box for fuse box. sounds like you are only getting 1 leg of the 220VAC to the machine.
Sep 19, 2009 | Maytag SDE3606A Electric Dryer
No sound at all!
There can be a host of problems with why you have lost sound ( could even be your tv via external audio ).I'd definately contact Sony and explain ; they're very good. They even replaced my son's PS2 which he'd already had for two years as the picture was wobbly : new one delivered next day and old one picked up ( all you need is the original box and proof of purchase, if it's second hand or you've thrown the box away, well be careful with 2nd hand electrical goods and always keep the box and receipt ! ).
Jul 24, 2009 | Disney Interactive Video Game Consoles &...
I am not able to swtich on
u go updated ure windows ok dude
Jun 19, 2009 | i-mate JAQ3 Smartphone
Blowing Relay Swtiches - Why?
the relays are getting moisture,if ya get stranded pull the relay,warm it up, under your armpit for a minute, and it should start.find a way to keep moisture out of the relay box.
Jan 16, 2009 | 2002 Suzuki Aerio
Honda atv wiring
you need a starter box w/c includes push swtich , install near the handle put attachement to bolt , wiring to starter red in color to box terminal, black wire connect to box terminal direct battery , install fuse depend to the starter amphere , series to black line positive + .connect green wire to the negative -- from battery to body of the strater or ground bolt. then start it. Thanks
Dec 29, 2007 | Karcher 2500 PSI Pressure Washer
M-Audio Fast Track Pro External Sound System Logo
140 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
dhnguyen
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
