Question about Cadence Weslo C62 Treadmill Walking Belt
Weslo cadence c62 belt slipping, how do I fix
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
SOURCE: given a Weslo Cadence 840 but panel is not providing read out
just got one myself not sure if you have yours question answered already but i will tell you anyway.. on the left hand side of your base read out there is a slide up panel and it takes 3 aa batteries to work the digital readout..
Posted on Aug 17, 2009
SOURCE: lost key for my weslo cadence 860
We found the key.
Thanx
Posted on Sep 03, 2009
  • 103 Answers
SOURCE: my weslo cadence 200 treadmill belt keeps slipping
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Posted on Nov 25, 2009
bwinton
  • 83 Answers
SOURCE: Adjusting the walking belt
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on Apr 30, 2010
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Change walking belt
see the next video :
sincerely. God bless you
May 01, 2012 | Cadence Weslo C62 Treadmill Walking Belt
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
Weslo cadence treadmill wont work
I centered the belt on my tredmill and now it wont move at all. I tighted and loosened the belt. motor runs belt wont move
Feb 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Weslo Cadence 450 Treadmill Manual
When turned on it acts like the walking surface is grabbing.Itgoes and stops its not as bad when speed is increased,but it still feels like it is grabbing.
Mar 22, 2009 | Cadence Exercise & Fitness
Cadence Weslo  C62 Treadmill Walking Belt Logo
233 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
