Question about Fellowes SB85C Shredder
Fellowes Shredder keeps running
We have a Fellowes SB85 shredder that continues to run without paper in it. I know it' s a sensor issue but we can't figure out how to clear the sensor.
Thanks,
John
  • 2 more comments
  • Anonymous Mar 13, 2014
    unit will not power up. No paper jams, motor and gears turn freely.
  • Anonymous Mar 14, 2014
    power cord receptacle is pushed into the body of the shredder. How can you disassemble body to get access to it?
  • Anonymous Mar 19, 2014
    The Shredder does not light up. The electrical cord is plugged in. The door is closed. I don't know what is wrong with the shredder.
  • Anonymous Mar 26, 2014
    how do i fix this?
    Scholar:
  • 102 Answers
You should be able to flip up the cd cover and visibly see the sensors in the center of the paper entry(look like little LED lightbulbs) Clean with a Q-tip dipped in rubbing alchohol. This should solve your problem. If it doesn't you probally have a burned out sensor. call 1-800-945-4545 to check with customer service.
Posted on Feb 22, 2008
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
Fellows C-320/C-320C shredder runs continuously. It will not stop. I have cleaned the paper sensors, and nothing seemed to change. When the machine is on and running, I(Auto On), O(Off), and R(Reverse)...
sounds as if you will need to have the auto feed sensor replaced. if they fail it will just run, thinking it sees paper. your machine is under warranty for three years from the date of purchase. call fellowes and see if they have repair depot in your area. 1-800-955-0959
Mar 31, 2011 | Fellowes C-320 Shredder
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
Crc 30102 shredder continues to run without paper in - touch sensor works ok
Blow some canned air down into the feed slot to clean the sensors.
Nov 30, 2009 | Fellowes 6-Sheet Cross-Cut Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
Nov 20, 2009 | Fellowes Powershred DM8C (Confetti)...
Why does my Fellowes Shredder(DM12C) run all the time I have the power switch on even though there is no paper in it.
You might check to see if there is anything lodged in the sensor of the shredder that triggers the shredder to continue to run. . .
Aug 13, 2009 | Office Equipment & Supplies
Shredder does not turn off
You need to clean the paper feed sensors. You can call Fellowes customer service at 1-800-945-4545
Feb 11, 2008 | Fellowes Powershred P-55C Light-Duty...
Fellowes SB85C Shredder Logo
1,026 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
