Question about Mitsubishi VS-60603 60" Rear Projection Television
Mitsubishi VS 60609 60 inch
I have Mitsubishi 60 inch.  I am looking for companel board or a diagram.
Please help.  You can email at Jean.Madera@navy.med.mil.
R,
Jean
I need a board for this television. Mine has burned out completely, but the rest of the television seems to funcition properly.
Anyone?
  • 3 more comments
  • Dustin Shaw Feb 23, 2008
    I am looking for the main board for the vs-60603. Sorry, the beginning of the thread says vs-60609.
    The board is about 12"x24" if I had to guess. All of the plugs were pulled and the entire board was taken out for repair. Unfortunately the TV repair person is not giving it back now, so I am just going to need to buy a new one. He couldn't find the problem, and it has now been 4+ months.
    If you could find me a vs-60603 main board it would be amazing. I really need this TV up and running. My email address is dustinshaw@hotmail.com
    The serial number is 104946 if that helps.
    He took the entire board that is on the very bottom of the casing. I'm not sure if that is the board you are referring to or not. It is a huge board, and it looked like one piece. It did have the power supply on it.
  • Dustin Shaw Feb 25, 2008
    I am willing to pay well to anyone that can find this board...
    Thank you! I'm not worried about getting the discount though. You deserve the extra money for helping me! Just let me know if you are able to locate one, and thanks again!
  • Dustin Shaw Jun 14, 2008
    BUMP!
    I still need an entire board for this TV.
  • Mitsubishi Master
  • 8,617 Answers
Which board are you looking for? I can probably help ypu out.
Posted on Feb 22, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Feb 23, 2008
    Okay you have the VZ5 chassis that model used 3 different Main PWB assembly boards. They ar 930B846003, 930B846005 and 930B846001. Let me do some research on which one your paticular model had in it and I will get back to you in a little bit. Am I correct in assuming that the board you are needed is on the left side of your chassis where the power supply and high voltage circuits are. As that is the main PWB assy. Let me know if I am correct.
  • Sonny Berry
    The board that was used in your set was the 930B846005 Unfortunately that board is no longer available, but let me continue to check my resources to see i I can locate one for you. I have allot of sources for used parts.
  • Sonny Berry
    Sonny Berry Feb 25, 2008
    I believe I can locate that board for you that is the VZ7 chassis. I work at a place that will possibly have one and they will give you my discount. I will check today and emai you this evening.
hi...
I did a search on based on the information you gave me and i found that if you look in ebay, you may find what you need under Mitsubishi 60 inch board.. in order to find the correct board you need, i would need your model #, etc.. i will research it if you provide me with the info..
I think this will help you find what you need though.. good luck..d
Feb 22, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Where can I get a diagram for Mitsubishi vs50805 A wiring diagram is what I mean.
I have the service manual for the vs chassis. I can email it to you. Post back with an email address.
Dec 04, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-55601 55 inch tv
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 10, 2017 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Mitsubishi 50 inch projection tv
you probably have a problem with the convergence board.
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5071 rear projection turns on, has audio but no video
That is a VZ3 chassis, similar to Mitsubishi models Ts-4545, Ts-5045, Ts-5545, Vs-4543, Vs-4544, Vs-5043, Vs-5044, Vs-5047, Vs-6043, Vs-6047 and has common failures in the vertical circuit, specifically vert Ic401 which is a La7845 which is usually caused by defective C402 100uf 50v and/or open 1.2 ohm 2 watt R510 next to FBT.
If not that check C268 off Q215 on signal board 22mf/50v and Ic200 on signal module Cxa2025s. However the vertical failure is more likely.
Bill
Sep 10, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Hi, I need a Diagram for a Mitsubishi VS-60609 my E-mail: varo9@hotmail.com Thanks!!!
Oct 16, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
