Question about Brother MFC-440CN InkJet Printer
Printer is not printing colors correctly. Brown looks red. Is there a way to clear ink heads or ink area. case shows ink spillage, need to clean up area maybe will help with color printing.
    President:
  • 2,306 Answers
You press the ink button and choose cleaning option and test print to see if colors are correct, clean again if colors are wrong. The spillage won't hurt print quality when it's around the cartridge area. If you are using generic inks they sometimes are not the correct color.
Posted on Feb 08, 2010
No red color appear when i print pictures
The Magenta print head nozzle maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 08, 2013 | Canon Pixma iP2700 InkJet Photo Printer
I have been printing photos and they have come out beautiful. Suddenly the colors are all muted, and brown hair has a green tint. My printer is an HP 6180. Nothing has changed - same paper, ink...
It sounds like one of the colors is not printing correctly. I would suggest , opening your hp solutions center programs and under tools you will find an option to clean the print heads. Follow the procedure to cleans the print heads, after cleaning open control panel on the computer and depending on the operating system click on "printers" (XP) or "devices and printers"(vista win7) right click on your printer( hit your right mouse button) select " printer properties" click on print test page. This page will print out showing each of the colors separately. You should see black, blue, pink and yellow. If one of these colors is missing or muted you will now which color is cratinging the issue. And at that time I would try changing the corresponding ink cartridge. Hopefully the print head cleaning will resolve your issue
Feb 11, 2013 | HP Photosmart C6180 All-In-One InkJet...
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Oct 07, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Theres something wrong in printing .. the printed paper have lines
Hi, printed lines? the waste is probably full. therefore causing ink to spill on the printed document.
Jan 26, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Print color different than on-screen color
Doe sthe nozzle check show ANY gaps? If not the n the colour difference is most likely down to the colour profile on your system in the software you use.
See if the software or printer vendor offer a colour profile for your OS.
Jul 05, 2008 | Epson Stylus Photo R300 InkJet Printer
Brother MFC-440CN InkJet Printer Logo
819 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
